TAI-TECH
P2
Wire Wound Type Common Mode Filter
WCM1210F2SF-SERIES
1. Features
1. High common mode impedance at high frequency cause excellent
Halogen
noise suppression performance.
2. WCM1210F2SF series realizes small size and low profile. 1.2x1.0x0.9 mm.
Halogen-free
3. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
4. Operating temperature-40~+125℃ (Including self - temperature rise)
2. Dimension
E
C
A
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
1210F2SF
1.2±0.2
1.0±0.2
0.9 max.
0.35±0.1
0.35±0.1 0.03 min.
D
D
B
3. Part Numbering
WCM 1210
A
B
F
2
S
F
C
D
E
F
900
T
02
G
H
I
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
S=Shielded , N=Unshielded
F: Lead free
G: Impedance
900=90Ω
H: Packaging
I: Rated Current
T=Taping and Reel
02=250mA
4. Specification
TAI-TECH
Part Number
DC
Common mode Test Frequency
Resistance
Impedance (Ω)
(MHz)
(Ω) max.
Rated Current Rated Volt. Withstand
IR
Volt. (Vdc) (Ω) min.
(mA)max.
(Vdc) max.
max.
WCM1210F2SF-600T02
60±25%
100
0.30
250
50
125
10M
WCM1210F2SF-900T02
90±25%
100
0.30
250
50
125
10M
WCM1210F2SF-121T02
120±25%
100
0.35
250
50
125
10M
WCM1210F2SF-161T01
160±25%
100
0.43
160
50
125
10M
WCM1210F2SF-201T01
200±25%
100
0.80
120
50
125
10M
www.tai-tech.com.tw
TAI-TECH
WCM1210F2SF-600T02
1000
Common Mode
100
10
Normal Mode
1
WCM1210F2SF-900T02
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
P3
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM1210F2SF-121T02
Common Mode
100
10
Normal Mode
1
0.1
10000
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
1000
10000
1
FREQUENCY(MHz)
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
10
100
FREQUENCY(MHz)
WCM1210F2SF-201T01
1000
IMPEDANCE(Ohm)
1000
WCM1210F2SF-161T01
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
1000
10000
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P4
WCM1608F2SNF-SERIES
1. Features
Halogen
2. WCM1608F2SNF series realizes small size and low profile. 1.6x0.8x1.1 mm.
Halogen-free
2. Dimension
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
1608F2SNF 1.60±0.15 0.85±0.15 1.10±0.15 0.30Typ. 0.30Typ. 0.03 min.
3. Part Numbering
WCM 1608
A
B
F
2
SN
F
C
D
E
F
900
T
05
G
H
I
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
F: Lead free
G: Impedance
900=90Ω
H: Packaging
T=Taping and Reel
I: Rated Current
05=550mA
4. Specification
TAI-TECH
Part Number
DC
Resistance
Impedance (Ω)
(MHz)
(Ω) max.
IR
(mA)max.
(Vdc) max.
max.
WCM1608F2SNF-220T05
22±25%
100
0.080
500
50
125
10M
WCM1608F2SNF-450T05
45±25%
100
0.110
500
50
125
10M
WCM1608F2SNF-900T05
90±25%
100
0.145
550
50
125
10M
WCM1608F2SNF-121T05
120±25%
100
0.175
500
50
125
10M
WCM1608F2SNF-181T05
180±25%
100
0.210
500
50
125
10M
WCM1608F2SNF-251T04
250±25%
100
0.280
400
50
125
10M
www.tai-tech.com.tw
TAI-TECH
WCM1608F2SNF-220T05
Common Mode
10
Normal Mode
1
WCM1608F2SNF-450T05
1000
IMPEDANCE(Ohm)
100
IMPEDANCE(Ohm)
P5
100
Common Mode
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM1608F2SNF-900T05
Common Mode
100
10
Normal Mode
1
10000
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM1608F2SNF-181T05
1000
IMPEDANCE(Ohm)
Common Mode
10
Normal Mode
1
0.1
1
10
100
1000
10000
WCM1608F2SNF-251T04
1000
100
100
FREQUENCY(MHz)
FREQUENCY(MHz)
IMPEDANCE(Ohm)
1000
WCM1608F2SNF-121T05
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
1000
10000
Common Mode
100
10
Normal Mode
1
0.1
1
FREQUENCY(MHz)
10
100
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P6
WCM2012F2SF-SERIES
1. Features
1. High common mode impedance at high frequency cause excellent noise
Halogen
2. WCM2012F2SF series realizes small size and low profile. 2.0x1.2x1.2 mm.
Halogen-free
4. Operating temperature -40~+125℃ (Including self - temperature rise)
2. Dimension
A
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
2012F2SF
2.0±0.2
1.2±0.2
1.2±0.2
0.50±0.1
0.51±0.1
0.15±0.1
E
C
Series
D
D
B
3. Part Numbering
WCM 2012
A
B
F
2
S
F
C
D
E
F
900
T
04
G
H
I
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
F: Lead free
G: Impedance
900=90Ω
H: Packaging
I: Rated Current
T=Taping and Reel
04=400mA
4. Specification
TAI-TECH
Part Number
DC
Impedance
Resistance
(MHz)
(Ω)
(Ω) max.
Rated Current
(mA)max.
Withstand
Rated Volt.
IR
(Vdc)max.
max.
WCM2012F2SF-670T04
67±25%
100
0.25
400
50
125
10M
WCM2012F2SF-900T04
90±25%
100
0.30
400
50
125
10M
WCM2012F2SF-121T04
120±25%
100
0.30
400
50
125
10M
WCM2012F2SF-161T03
160±25%
100
0.35
350
50
125
10M
WCM2012F2SF-181T03
180±25%
100
0.35
350
50
125
10M
WCM2012F2SF-201T03
200±25%
100
0.40
300
50
125
10M
WCM2012F2SF-221T03
220±25%
100
0.40
300
50
125
10M
WCM2012F2SF-261T03
260±25%
100
0.40
300
50
125
10M
WCM2012F2SF-361T03
360±25%
100
0.50
300
50
125
10M
www.tai-tech.com.tw
TAI-TECH
P7
Typical Impedance v.s. Frequency Curve
WCM2012F2SF-670T04
Common Mode
100
10
Normal Mode
1
WCM2012F2SF-900T04
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM2012F2SF-121T04
Common Mode
100
10
Normal Mode
1
0.1
Common Mode
100
10
Normal Mode
1
10
100
1000
10000
1
10
FREQUENCY(MHz)
1000
10000
WCM2012F2SF-201T03
1000
IMPEDANCE(Ohm)
1000
Common Mode
100
100
FREQUENCY(MHz)
WCM2012F2SF-181T03
10000
IMPEDANCE(Ohm)
10000
0.1
1
10
Normal Mode
1
0.1
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
1000
10000
1
10
FREQUENCY(MHz)
IMPEDANCE(Ohm)
10
Normal Mode
1
1000
10000
WCM2012F2SF-261T03
1000
Common Mode
100
100
FREQUENCY(MHz)
WCM2012F2SF-221T03
1000
IMPEDANCE(Ohm)
1000
WCM2012F2SF-161T03
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
10000
1
10
100
FREQUENCY(MHz)
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P8
WCM2012F2SF-361T03
10000
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
1000
10000
FREQUENCY(MHz)
3. Part Numbering
WCM 2012
A
B
F
2
S
F
C
D
E
F
801
N
G
H
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
F: Lead free
G: Impedance
H: Category Code
801=800Ω
N=DR-N45 材&SP-N45 材
4. Specification
TAI-TECH
Part Number
WCM2012F2SF-801-N
DC
Impedance
Resistance
(MHz)
(Ω)
(Ω) max.
800±25%
100
Rated Current
(mA)max.
0.88
Withstand
Rated Volt.
IR
(Vdc)max.
max.
300
50
WCM2012F2SF-801-N
10000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
Common Mode
1000
100
10
Normal Mode
1
1
10
100
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
125
10M
TAI-TECH
P9
WCM3216F2SF-SERIES
1. Features
Halogen
2. WCM3216F2SF series realizes small size and low profile. 3.2x1.6x2.0 mm.
Halogen-free
2. Dimension
C
A
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
3216F2SF
3.2±0.2
1.6±0.2
2.0±0.2
0.5±0.1
0.5±0.1
0.15±0.1
E
Units: mm
D
D
B
3. Part Numbering
WCM 3216
A
B
A: Series
B: Dimension
C: Material
D: Number of Lines
E: Type
F: Lead free type
G: Impedance
H: Packaging
I: Rated Current
F
2
S
F
C
D
E
F
900
T
04
G
H
I
Ferrite Core
2=2 lines
900=90Ω
T=Taping and Reel
04=400mA
4. Specification
TAI-TECH
Part Number
DC
Common mode
Impedance Test Frequency Resistance
(MHz)
(Ω)
(Ω) max.
Rated Current
(mA)max.
Withstand
IR
Rated Volt.
(Vdc)max. Volt. (Vdc) (Ω) min.
Max.
WCM3216F2SF-900T04
90±25%
100
0.30
400
50
125
10M
WCM3216F2SF-121T03
120±25%
100
0.30
350
50
125
10M
WCM3216F2SF-161T03
160±25%
100
0.40
350
50
125
10M
WCM3216F2SF-221T03
220±25%
100
0.45
300
50
125
10M
WCM3216F2SF-261T03
260±25%
100
0.50
300
50
125
10M
WCM3216F2SF-361T03
360±25%
100
0.60
300
50
125
10M
WCM3216F2SF-601T03
600±25%
100
0.80
300
50
125
10M
WCM3216F2SF-102T02
1000±25%
100
1.00
200
50
125
10M
WCM3216F2SF-222T02
2200±25%
100
1.20
200
50
125
10M
www.tai-tech.com.tw
TAI-TECH
P10
WCM3216F2SF-900T04
Common Mode
100
10
Normal Mode
1
WCM3216F2SF-121T03
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM3216F2SF-161T03
Common Mode
100
Normal Mode
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM3216F2SF-261T03
Common Mode
100
1000
10000
WCM3216F2SF-361T03
10000
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
Normal Mode
10
1
Common Mode
100
Normal Mode
10
1
0.1
0.1
1
10
100
1000
10000
1
10
FREQUENCY(MHz)
1000
10000
WCM3216F2SF-102T02
10000
IMPEDANCE(Ohm)
Common Mode
1000
100
FREQUENCY(MHz)
WCM3216F2SF-601T03
10000
IMPEDANCE(Ohm)
10000
1000
10
1
1000
WCM3216F2SF-221T03
10000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
100
10
Normal Mode
1
Common Mode
1000
100
10
Normal Mode
1
0.1
1
10
100
1000
10000
1
10
100
FREQUENCY(MHz)
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P11
WCM3216F2SF-222T02
IMPEDANCE(Ohm)
10000
Common Mode
1000
100
10
Normal Mode
1
1
10
100
1000
10000
FREQUENCY(MHz)
www.tai-tech.com.tw
TAI-TECH
P12
WCM3225F2SF-SERIES
1. Features
Halogen
2. WCM3225F2SF series realizes small size and low profile. 3.2x2.5x2.2 mm.
Halogen-free
2. Dimension
C
A
Series
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
3225F2SF
3.2±0.2
2.5±0.2
2.2±0.2
0.8±0.1
0.9±0.1
0.15±0.1
E
Units: mm
D
D
B
3. Part Numbering
WCM 3225
A
B
F
2
S
F
C
D
E
F
102
T
04
G
H
I
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
F: Lead free type
G: Impedance
102=1000Ω
H: Packaging
T=Taping and Reel
I: Rated Current
04=400mA
4. Specification
TAI-TECH
Part Number
DC
Common mode
Withstand
IR
Rated Volt.
Impedance Test Frequency Resistance Rated Current (Vdc)max. Volt. (Vdc) (Ω) min.
(MHz)
(mA)max.
(Ω)
max.
(Ω) max.
WCM3225F2SF-900T10
90±25%
100
0.050
1000
50
125
10M
WCM3225F2SF-261T10
260±25%
100
0.15
1000
50
125
10M
WCM3225F2SF-601T10
600±25%
100
0.20
1000
50
125
10M
WCM3225F2SF-102T04
1000±25%
100
0.30
400
50
125
10M
www.tai-tech.com.tw
TAI-TECH
WCM3225F2SF-900T10
1000
Common Mode
100
10
Normal Mode
1
0.1
1
10
100
1000
WCM3225F2SF-261T10
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
P13
Common Mode
100
10
Normal Mode
1
0.1
10000
1
10
FREQUENCY(MHz)
WCM3225F2SF-601T10
10000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
10000
Common Mode
1000
100
10
Normal Mode
1
1000
WCM3225F2SF-102T04
10000
Common Mode
1000
100
FREQUENCY(MHz)
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
10000
1
10
100
FREQUENCY(MHz)
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P14
WCM4532F2SF-SERIES
1. Features
Halogen
2. WCM4532F2SF series realizes small size and low profile. 4.5x3.2x2.8 mm.
Halogen-free
2. Dimension
A
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
4532F2SF
4.5±0.2
3.2±0.2
2.8±0.2
1.0±0.1
1.2±0.1
C
Series
B
D
D
Units: mm
D
D
3. Part Numbering
WCM 4532
A
B
F
2
S
F
C
D
E
F
900
T
30
G
H
I
A: Series
B: Dimension
C: Material
Ferrite Core
D: Number of Lines
2=2 lines
E: Type
F: Lead free
G: Impedance
900=90Ω
H: Packaging
T=Taping and Reel
I: Rated Current
30=3000mA
4. Specification
TAI-TECH
Part Number
DC
Common mode
(MHz)
(Ω)
(Ω) max.
Rated Current
(mA) max.
IR
Volt. (Vdc)
(Ω) min.
(Vdc) max.
max.
80±25%
100
0.05
3000
50
125
10M
WCM4532F2SF-900T30
90±25%
100
0.05
3000
50
125
10M
WCM4532F2SF-121T30
120±25%
100
0.05
3000
50
125
10M
WCM4532F2SF-201T15
200±25%
100
0.10
1500
50
125
10M
WCM4532F2SF-601T15
600±25%
100
0.24
1500
50
125
10M
WCM4532F2SF-801T10
800±25%
100
0.24
1000
50
125
10M
WCM4532F2SF-800T30
www.tai-tech.com.tw
TAI-TECH
WCM4532F2SF-800T30
1000
IMPEDANCE(Ohm)
10
Normal Mode
1
WCM4532F2SF-900T30
1000
Common Mode
100
IMPEDANCE(Ohm)
P15
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM4532F2SF-121T30
Common Mode
100
10
Normal Mode
1
10000
Common Mode
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
1
10000
10
WCM4532F2SF-601T15
10000
10000
Common Mode
IMPEDANCE(Ohm)
1000
100
10
Normal Mode
1
1000
WCM4532F2SF-801T10
10000
Common Mode
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
IMPEDANCE(Ohm)
1000
WCM4532F2SF-201T15
1000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
100
FREQUENCY(MHz)
FREQUENCY(MHz)
100
10
Normal Mode
1
0.1
0.1
1
10
100
1000
10000
1
10
100
FREQUENCY(MHz)
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
10000
TAI-TECH
P16
Reliability and Test Condition (WCM1210, 1608, 2012, 3216, 3225, 4532)
Item
Performance
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Z(common mode)
DCR
Keysight E4991B + Keysight 16197A
Refer to standard electrical characteristics list.
Agilent-34420A
Agilent-4338B
I.R.
Chroma 19073
Temperature Rise Test
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
Rated Current ΔT 40℃Max
Reliability Test
Preconditioning: Run through reflow for 3 times.( IPC/JEDEC
J-STD-020E Classification Reflow Profiles)
Temperature:125±2℃
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24 hrs.
Humidity:85±3% R.H,
Load Humidity
Temperature:85℃±2℃
Duration : 1000hrs Min. Bead : with 100% rated current ,
Inductance: with 10% rated current
Moisture Resistance
Appearance:No damage.
Impedance:within±15% of initial value
RDC:within ±15% of initial value and shall not
exceed the specification value
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:125±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Vibration
www.tai-tech.com.tw
TAI-TECH
P17
Item
Performance
Bending
Shock
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805:1kg , =0805 inch(2012mm):40x100x1.2mm
0805:1kg ,
WCM 2012F2SF-900T04 价格&库存
很抱歉,暂时无法提供与“WCM 2012F2SF-900T04”相匹配的价格&库存,您可以联系我们找货
