找到CPB165相关的规格书共7,752
型号厂商描述数据手册替代料参考价格
NACEW330K165X5.5TR13FNIC[NIC-ComponentsCorp.] NACEW330K165X5.5TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp.获取价格
NACEW100M165X5.5TR13FNIC[NIC-ComponentsCorp.] NACEW100M165X5.5TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp.获取价格
VSKD196-12PBFVISHAY[VishaySiliconix] VSKD196-12PBF - Standard Recovery Diodes, 165 A to 230 A (INT-A-PAK Power Modules) - Vishay Siliconix获取价格
VSKD166-08PBFVISHAY[VishaySiliconix] VSKD166-08PBF - Standard Recovery Diodes, 165 A to 230 A (INT-A-PAK Power Modules) - Vishay Siliconix获取价格
NACCR33K165X6.1TR13FNIC[NIC-ComponentsCorp.] NACCR33K165X6.1TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp.获取价格
NACCR10M165X6.1TR13FNIC[NIC-ComponentsCorp.] NACCR10M165X6.1TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp.获取价格
NACC220M165X6.1TR13FNIC[NIC-ComponentsCorp.] NACC220M165X6.1TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp.获取价格
SD-49624-001MOLEX6[MolexElectronicsLtd.] SD-49624-001 - 4.20mm (.165") Wire-to-Wire TPA™ Connector for Female Housing - Molex Electronics Ltd.获取价格
SD-35318-0420MOLEX4[MolexElectronicsLtd.] SD-35318-0420 - 4.20mm (.165") Pitch Mini-Fit® Header - Molex Electronics Ltd.获取价格
CL-165HRCITIZEN[CITIZENELECTRONICSCO.,LTD.] CL-165HR - Multi-Color Upward-Lighting Type - CITIZEN ELECTRONICS CO., LTD.获取价格
RE46C165TS16TFMICROCHIP[MicrochipTechnology] RE46C165TS16TF - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology获取价格
RE46C165SWMICROCHIP[MicrochipTechnology] RE46C165SW - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology获取价格
RE46C165E16FMICROCHIP[MicrochipTechnology] RE46C165E16F - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology获取价格
FC250F1MACOM[TycoElectronics] FC250F1 - Power Module: dc-dc Converter; 18 Vdc to 36 Vdc Input, 3.3 Vdc Output; 165 W - Tyco Electronics获取价格
MM74HC165MXFAIRCHILD[FairchildSemiconductor] MM74HC165MX - Parallel-in/Serial-out 8-Bit Shift Register - Fairchild Semiconductor获取价格
R5F562TAEDFPRENESAS[RenesasTechnologyCorp] R5F562TAEDFP - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp获取价格
R5F562TADDFPRENESAS[RenesasTechnologyCorp] R5F562TADDFP - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp获取价格
R5F562TAADFHRENESAS[RenesasTechnologyCorp] R5F562TAADFH - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp获取价格
R5F562T7DDFFRENESAS[RenesasTechnologyCorp] R5F562T7DDFF - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp获取价格
R5F562T7BDFHRENESAS[RenesasTechnologyCorp] R5F562T7BDFH - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp获取价格
