找到“CPB165”相关的规格书共7,752个
| 型号 | 厂商 | 描述 | 数据手册 | 替代料 | 参考价格 |
| NACC101M165X6.1TR13F | NIC[NIC-ComponentsCorp.] | NACC101M165X6.1TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp. | 获取价格 | ||
| NACC100M165X6.1TR13F | NIC[NIC-ComponentsCorp.] | NACC100M165X6.1TR13F - Surface Mount Aluminum Electrolytic Capacitors - NIC-Components Corp. | 获取价格 | ||
| SDA-44472-2256 | MOLEX6[MolexElectronicsLtd.] | SDA-44472-2256 - 4.20mm (.165") Pitch Mini-Fit HCS™ Header - Molex Electronics Ltd. | 获取价格 | ||
| SD-49626-001 | MOLEX6[MolexElectronicsLtd.] | SD-49626-001 - 4.20mm (.165") Wire-to-Wire Lower TPA for Male Housing, 8 Circuits - Molex Electronics Ltd. | 获取价格 | ||
| SD-49623-001 | MOLEX6[MolexElectronicsLtd.] | SD-49623-001 - 4.20mm (.165") Wire-to-Wire TPA™ Connector for Male Housing - Molex Electronics Ltd. | 获取价格 | ||
| SD-35317-1420 | MOLEX4[MolexElectronicsLtd.] | SD-35317-1420 - 4.20mm (.165") Pitch Mini-Fit® Header, Dual Row, - Molex Electronics Ltd. | 获取价格 | ||
| 0366330034 | MOLEX5[MolexElectronicsLtd.] | 0366330034 - 4.20mm (.165") Mini-Fit Jr.â„¢ Header, Vertical, Nylon, without Flange, 4 Circuits - Molex Electronics Ltd. | 获取价格 | ||
| RE46C165TE16TF | MICROCHIP[MicrochipTechnology] | RE46C165TE16TF - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology | 获取价格 | ||
| RE46C165SW16TF | MICROCHIP[MicrochipTechnology] | RE46C165SW16TF - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology | 获取价格 | ||
| RE46C165SW16F | MICROCHIP[MicrochipTechnology] | RE46C165SW16F - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology | 获取价格 | ||
| RE46C165S16F | MICROCHIP[MicrochipTechnology] | RE46C165S16F - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology | 获取价格 | ||
| RE46C165E16TF | MICROCHIP[MicrochipTechnology] | RE46C165E16TF - CMOS Photoelectric Smoke Detector ASIC with Interconnect, Timer Mode and Alarm Memory - Microchip Technology | 获取价格 | ||
| R5F562TADDFF | RENESAS[RenesasTechnologyCorp] | R5F562TADDFF - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp | 获取价格 | ||
| R5F562TAADFF | RENESAS[RenesasTechnologyCorp] | R5F562TAADFF - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp | 获取价格 | ||
| R5F562T7EDFP | RENESAS[RenesasTechnologyCorp] | R5F562T7EDFP - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp | 获取价格 | ||
| R5F562T7DDFP | RENESAS[RenesasTechnologyCorp] | R5F562T7DDFP - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp | 获取价格 | ||
| R5F562T7BDFF | RENESAS[RenesasTechnologyCorp] | R5F562T7BDFF - 100-MHz 32-bit RX MCUs, FPU, 165 DMIPS, 12-bit ADC - Renesas Technology Corp | 获取价格 | ||
| 0191951031 | MOLEX4[MolexElectronicsLtd.] | 0191951031 - MagKrimpâ„¢ Round Ring with Ribbed Barrel, Stud Size 3/8", 165,000-230,000 CircularMil Area, Plated - Molex Electronics Ltd. | 获取价格 | ||
| ERJ2RHD1650X | Panasonic Corporation | Res Thick Film 0402 165 Ohm 0.5% 0.063W(1/16W) ±50ppm/C Molded SMD Automotive Punched T/R | 获取价格 | ||
| FNR5020S150MT | Changjiang Microelectronics Technology Co., Ltd. | 5.0*5.0*2.0(5020) 电感值:15µH 精度:±20% 饱和电流(isat):1.4A 温升电流(irms):1.3A 直流电阻(DCR):165mΩ | 获取价格 |
