AW9109QNR
AW9109QNR
    AWINIC(艾为)
    TQFN-20L-EP(3x3)
    呼吸灯驱动BREATHING LED DRIVER 停产
AW9109QNR 数据手册
AW9109 Feb. 2019 V1.4 9 Programmable LED Driver GENERAL DESCRIPTION  AW9109 integrates a SRAM program-controlled 9 LED driver. 9 LED driver uses common anode current source and PWM dimming. Each LED is 8-level driver current selectable with dimming independently controlled by external MCU or internal 256word*16bit SRAM program.  ti a n Compatible I2C interface of 400kHz fast mode is provided. It requires only 3.0V-4.5V single power supply. e   8-level LED Maximum Current for each LED, max 24.5mA Internal ASP with 256*16bit SRAM Programmable to Achieve Custom Light Effect 256-level Linear/Logarithmic PWM Dimming,9 bits PWM resolution Compatible I2C Interface, VIO: 1.8V ~ 3.3V Single Power Supply, Voltage Range: 3.0V ~ 4.5V QFN 3mm×3mm×0.75mm- 20L Package fi d    l FEATURES APPLICATIONS Mobile Phones, MID n Portable Media Player o Home Appliances C TYPICAL APPLICATION CIRCUIT VBAT ic MCU/BB VBAT LED1 1mF 4.7kΩ x3 AD LED3 GND LED4 GND LED5 GND AW9109 LED6 SCL SCL SDA SDA INTN INTN LED8 GPO PDN LED9 a w in VIO LED2 LED7 Figure 1 AW9109 Typical Application Circuit All trademarks are the property of their respective owners. www.awinic.com.cn 1 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 CONTENT PIN CONFIGURATION AND TOP MARK.................................................................................................... 4 2 PIN DEFINITION ........................................................................................................................................... 4 3 FUNCTIONAL BLOCK DIAGRAM ............................................................................................................... 5 4 TYPICAL APPLICATION CIRCUITS ........................................................................................................... 5 5 ORDERING INFORMATION ........................................................................................................................ 6 6 ABSOLUTE MAXIMUM RATINGS(NOTE 3) .................................................................................................... 6 7 ELECTRICAL CHARACTERISTICS ............................................................................................................ 7 8 I2C INTERFACE TIMING .............................................................................................................................. 8 9 FUNCTIONAL DESCRIPTION ..................................................................................................................... 9 e n ti a l 1 fi d 9.1 WORK MODE ....................................................................................................................................................... 9 9.1.1 POWER ON ............................................................................................................................................. 9 9.1.2 WORK MODE .......................................................................................................................................... 9 HARDWARE RESET ........................................................................................................................... 10 9.2.2 SOFTWARE RESET ........................................................................................................................... 10 I 2C n 9.2.1 INTERFACE .................................................................................................................................................. 10 o 9.3 RESET ................................................................................................................................................................ 10 9.3.1 DEVICE ADDRESS ............................................................................................................................. 10 9.3.2 DATA VALIDATION ............................................................................................................................. 10 9.3.3 ACK(ACKNOWLEDGEMENT)............................................................................................................. 10 9.3.4 I2C START/STOP ................................................................................................................................ 11 C 9.2 9.3.5 WRITE CYCLE .................................................................................................................................... 11 READ CYCLE ...................................................................................................................................... 12 ic 9.3.6 9.4 OSCILLATOR ..................................................................................................................................................... 13 9.5 LED DRIVER ...................................................................................................................................................... 13 LED BRIGHTNESS CONTROLLER .................................................................................................... 13 9.5.2 LED CONSTANT CURRENT DRIVER ................................................................................................ 13 9.5.3 ASP ..................................................................................................................................................... 14 in 9.5.1 REGISTER DESCRIPTION ......................................................................................................................22 w 10 REGISTER CONFIGURATION ......................................................................................................................... 22 10.2 GLOBAL REGISTER DESCRIPTION ............................................................................................................... 23 a 10.1 10.3 10.2.1 IDRST, CHIP ID AND SOFTWARE RESET ...................................................................................... 23 10.2.2 GCR, GLOBAL CONTROL REGISTER ............................................................................................. 23 LED EFFECT CONTROL REGISTER .............................................................................................................. 23 10.3.1 LER1, LED DRIVER ENABLE REGISTER ........................................................................................ 23 10.3.2 LCR, LED EFFECT CONFIGURATION REGISTER ......................................................................... 23 10.3.3 PMD, PROGRAM MODE REGISTER ............................................................................................... 23 10.3.4 RMD, PROGRAM RUN MODE REGISTER ...................................................................................... 24 www.awinic.com.cn 2 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 10.3.5 CTRSR, LED CONTROL SOURCE SELECTION REGISTER .......................................................... 24 10.3.6 IMAX1~IMAX6, LEDX MAXIMUM OUTPUT CURRENT REGISTER ............................................... 24 10.3.7 LISR, LED INTERRUPT STATUS REGISTER .................................................................................. 24 SADDR, PROGRAM START ADDRESS REGISTER ....................................................................... 25 10.3.9 PCR, LED PROGRAM CONTROL POINTER REGISTER ................................................................ 25 10.3.10 CMDR, LED COMMAND REGISTER .............................................................................................. 25 10.3.11 RA/RB/RC/RD,LED INTERNAL PROGRAM REGISTER ................................................................ 25 10.3.12 R1~R8, LED INTERNAL DATA REGISTER .................................................................................... 25 10.3.13 GRP, LED GROUP OPERATION REGISTER................................................................................. 25 ti a l 10.3.8 10.3.14 WADDR, LED PROGRAM LOADING ADDRESS REGISTER ........................................................ 26 10.3.15 WDATA, LED PROGRAM LOADING DATA REGISTER ................................................................ 26 11 n 10.3.16 WPR, WRITING PROTECTION REGISTER ................................................................................... 26 TAPE AND REEL INFORMATION ...........................................................................................................27 CARRIER TAPE................................................................................................................................................ 27 11.2 PIN1 DIRECTION ............................................................................................................................................. 27 11.3 REEL................................................................................................................................................................. 28 fi d e 11.1 PACKAGE DESCRIPTION ......................................................................................................................29 13 RECOMMENDED LAND PATTERN ........................................................................................................29 14 REFLOW ...................................................................................................................................................30 15 REVISION HISTORY ................................................................................................................................31 16 DISCLAIMER ............................................................................................................................................32 a w in ic C o n 12 www.awinic.com.cn 3 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 PIN CONFIGURATION AND TOP MARK GND LED7 LED8 LED9 NC 15 14 13 12 11 17 9 GND LED4 18 8 VBAT LED3 19 7 PDN GND 20 6 AD 5 e INTN SCL SDA LED1 LED2 fi d NAME 1 LED2 LED2 cathode driver, anode connected to VBAT 2 LED1 LED1 cathode driver, anode connected to VBAT 3 SDA Data I/O of I2C Interface 4 SCL Clock input of I2C Interface 5 INTN Open-drain Interrupt output, low active. Typically connected to VIO via a 4.7kΩ resistor. (floating if not unused) 6 AD 7 PDN 9 o C I2C address select pin Power-down input , low active, internal 1MΩ pull-down resistor VBAT Power supply (3.0V to 4.5V) GND Ground NC in 10 DESCRIPTION n No. 8 NC 11 NC 12 LED9 LED9 cathode driver, anode connected to VBAT 13 LED8 LED8 cathode driver, anode connected to VBAT 14 LED7 LED7 cathode driver, anode connected to VBAT 15 GND Ground 16 LED6 LED6 cathode driver, anode connected to VBAT 17 LED5 LED5 cathode driver, anode connected to VBAT 18 LED4 LED4 cathode driver, anode connected to VBAT 19 LED3 LED3 cathode driver, anode connected to VBAT 20 GND Ground w a AW9109-AW9109QNR XXXX-Production Tracing Code PIN DEFINITION ic 2 AW9109 XXXX n LED5 4 NC 3 10 2 16 1 LED6 l AW9109 Marking AW9109 Top View ti a 1 www.awinic.com.cn NC 4 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 3 FUNCTIONAL BLOCK DIAGRAM LED1 LED2 ASP VBAT LDO OSC ti a LED4 LED DRIVER l LED3 LED5 LED6 GND n LED7 LED8 GND Figure 2 4 SDA PDN INTN LED9 fi d SCL e I2 C AD FUNCTIONAL BLOCK DIAGRAM TYPICAL APPLICATION CIRCUITS n VBAT o MCU/BB VBAT LED1 C 1mF LED2 GND LED5 AD VIO LED3 GND ic 4.7kΩ x3 LED4 GND AW9109 LED6 SCL SDA SDA INTN INTN LED8 GPO PDN LED9 LED7 Figure 3 AW9109 Typical Application Circuit a w in SCL www.awinic.com.cn 5 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 ORDERING INFORMATION AW9109QNR Temperature -40℃~85℃ Package Marking 3mm×3mm×0.75mm QFN-20L AW9109 Moisture Sensitivity Level MSL3 Environmental Information Delivery Form ROHS+HF 6000 unit / Tape and Reel fi d ABSOLUTE MAXIMUM RATINGS(NOTE 3) 6 PARAMETERS Supply voltage range VBAT SCL, SDA n Input voltage range RANGE -0.3V to 5V -0.3V to 3.6V PDN, LED1~LED9 -0.3V to 4.5V SDA, INTN -0.3V to 3.6V o Output voltage range e Package Type QN: QFN n AW9109 Shipping R: Tape & Reel C Junction-to-ambient thermal resistance θJA 45℃/W -40℃ to 85℃ Operating free-air temperature range 150℃ Maximum Junction temperature TJMAX ic l Part Number ti a 5 -65℃ to 150℃ Storage temperature TSTG Lead Temperature (Soldering 10 Seconds) 260℃ in ESD(NOTE 4) HBM (human body model) ±4kV w Latch-up +IT:450mA -IT:-450mA a Test Condition: JEDEC STANDARD NO.78B DECEMBER 2008 NOTE3: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE4: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883G Method 3015.7 www.awinic.com.cn 6 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 7 ELECTRICAL CHARACTERISTICS VBAT=3.8V, TA=25℃ for typical values (unless otherwise noted) Power supply - 3.0 Current in Shutdown mode PDN=GND 8 ISTANDBY Current in Standby mode PDN=VIO 130 IACTIVE Current in Active mode PDN=VIO, GCR=0x01 0.55 VBAT ISHUTDOWN Internal oscillator FOSC 14.8 Frequency accuracy (16MHz) Digital Logical Interface SDA,SCL,PDN VIH Logic input high level SDA,SCL,PDN IIL Low level input current SDA,SCL,PDN IIH High level input current SDA,SCL,PDN Logic output low level IOL Maximum output current IL Output leakage current mA 0.8 mA 17.2 MHz V V 5 nA 0.4 V SDA, INTN 10 mA SDA,INTN open drain 1 mA 400 kHz n C ns SDA deglitch time 250 ns LED MAX Current ILED=24.5mA Matching accuracy Drop-out voltage 18.5 24.5 30.5 mA ILED=24.5mA 10 % ILED=24.5mA 300 mV LCR.FREQ=1 110 122 135 Hz LCR.FREQ =0 220 244 270 Hz PWM frequency w FPWM 160 200 in IMATCH mA nA IOUT=3mA ic IMAX 15 SCL deglitch time TDeglitch LED Driver V 5 I2C-BUS clock frequency FSCL 4.5 0.9 o I2C Interface UNIT 0.45 SDA, INTN VOL VDROP -0.3 16 MAX e Logic input low level fi d VIL TYP l MIN ti a TEST CONDITION n PARAMETER a NOTE5:the value is tested in default configuration. www.awinic.com.cn 7 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Parameter Name TDEGLITCH Deglitch time SDA 250 ns Low level width of SCL 1.3 THIGH High level width of SCL 0.6 TSU:STA (Repeat-start) Start condition setup time 0.6 THD:DAT Data hold time 0 TSU:DAT Data setup time 0.1 TR Rising time of SDA and SCL TF Falling time of SDA and SCL TSU:STO Stop condition setup time TBUF Time between start and stop condition o n tHD:STA Start μs tHD:DAT μs μs μs 0.3 μs 0.3 μs 0.6 μs 1.3 μs VIH VIL tSP tF VIH VIL tSU:DAT tSU:STA Start tSU:STO Stop a w in ic Stop μs C SCL tHIGH μs fi d TLOW tR kHz ns 0.6 tLOW 400 200 (Repeat-start) Start condition hold time tBUF UNIT SCL THD:STA SDA MAX ti a Interface Clock frequency TYP n FSCL MIN l I2C INTERFACE TIMING e 8 www.awinic.com.cn 8 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 9 FUNCTIONAL DESCRIPTION 9.1 WORK MODE 9.1.1 Power On ti a l After power-up, about 100μs delay is required before PDN set to high, otherwise, the device may work incorrectly. The minimal wait time for I2C communication is 5ms, during this period, some internal modules (such as LDO) start to work and reach a stable state. VBAT 100μs Note: About 100μs delay is required after power on n PDN 5ms Note: The minimal wait time for I2C communication is 5ms Figure 4 fi d e I2C AW9109 Power On 9.1.2 Work Mode o n VBAT Power On Shutdown C PDN=0 PDN=1 Registers Initialization Software Reset ic in LDO enable, powering internal digital module Delay 5ms PDN=0 I2C available, LED control & output shutdown, Standby LEDE=1 LEDE=0 PDN=0 w Internal LDO shutdown, minimum power dissipation Active Figure 5 I2C available, LED control & output enable AW9109 Work Mode a After VBAT powered on, if PDN pin is low, the AW9109 is in shut-down mode, the current consumption is less than 15mA. When PDN pin becomes high, the internal LDO is activated, and a power-on reset (POR) signal is generated to initialize all internal registers, the device enters standby mode, this is a low power consumption mode, when all circuit functions are disabled. In standby mode, I2C interface is active, all internal configuration register can be written. If control bit GCR.LEDE is written high, the device enters the active mode. www.awinic.com.cn 9 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 9.2 9.2.1 RESET Hardware Reset When PDN pin changes from low to high, the power-up reset (POR) signal is generated, all internal registers are reset. Software Reset 9.3 to reset all internal registers. ti a Writing 0x55AA to register RSTR via I2C interface will activate a software reset l 9.2.2 I2C INTERFACE Device Address e 9.3.1 n AW9109 supports the I²C serial bus and data transmission protocol in fast mode at 400kHz. It operates as a slave on the I²C bus. Connections to the bus are made via the open-drain I/O pins SCL and SDA. The pull-up resistor can be selected in the range of 1k~10kΩ and the typical value is 4.7kΩ. AW9109 can support different high level (1.8V~3.3V) of this I2C interface. 0 1 0 1 0 AD R/W Device Address Configuration Data Validation o 9.3.2 1 n Figure 6 fi d The I2C device address (7-bit, followed by the R/W bit(Read=1/Write=0)) of AW9109 is 0x2C/0x2D. C When SCL is high level, SDA level must be constant. SDA can be changed only when SCL is low level. SDA 9.3.3 in ic SCL Data Line Stable Data Valid Figure 7 Change of Data Allowed Data Validation Diagram ACK(Acknowledgement) w ACK means the successful transfer of I2C bus data. After master sends 8bits data, SDA must be released; SDA is pulled to GND by slave device when slave acknowledges. a When master reads, AW9109 sends 8bit data, releases the SDA and waits for ACK from master. If ACK is send and I2C stop is not send by master, AW9109 sends the next data. If ACK is not send by master, AW9109 stops to send data and waits for I2C stop. www.awinic.com.cn 10 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Data Output by Transmiter Not Acknowledge(NACK) Data Output by Receiver Acknowledge(ACK) 8 9 Figure 8 9.3.4 ti a Clock Pulse for Acknowledgement START condition l 2 1 SCL From Master I2C ACK Timing I2C Start/Stop n I2C start: SDA changes form high level to low level when SCL is high level. SDA SCL S/Sr fi d e I2C stop: SDA changes form low level to high level when SCL is high level. P 9.3.5 Write Cycle I2C Start/Stop Condition Timing C Figure 9 P: STOP condition o n S: START condition Sr: START Repeated condition ic One data bit is transferred during each clock pulse. Data is sampled during the high state of the serial clock (SCL). Consequently, throughout the clock’s high period, the data should remain stable. Any changes on the SDA line during the high state of the SCL and in the middle of a transaction, aborts the current transaction. New data should be sent during the low SCL state. This protocol permits a single data line to transfer both command/control information and data using the synchronous serial clock. in Each data transaction is composed of a Start Condition, a number of byte transfers (set by the software) and a Stop Condition to terminate the transaction. Every byte written to the SDA bus must be 8 bits long and is transferred with the most significant bit first. After each byte, an Acknowledge signal must follow. a w In a write process, the following steps should be followed: a) Master device generates START condition. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. b) Master device sends slave address (7-bit) and the data direction bit (W = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master sends data high 8Bit to be written to the addressed register g) Slave sends acknowledge signal www.awinic.com.cn 11 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Master sends data low 8Bit to be written to the addressed register I) Slave sends acknowledge signal j) Master generates STOP condition to indicate write cycle end 0 SDA A6 Start 1 A5 2 A4 3 A3 4 A2 5 6 7 8 0 1 A0 R/W Ack A7 A1 2 A6 I2C Address A5 A4 4 A3 5 6 A2 A1 7 A0 8 0 1 2 3 4 5 6 Ack D15 D14 D13 D12 D11 D10 D9 Register Address 7 8 0 1 ... 6 D6 …… D1 D8 Ack D7 7 D0 Register Low 8BIt Register High 8Bit AW9109 I2C Write Timing Figure 10 9.3.6 3 8 Ack Stop ti a SCL l h) Read Cycle n In a read cycle, the following steps should be followed: Master device generates START condition b) Master device sends slave address (7-bit) and the data direction bit (W = 0). c) Slave device sends acknowledge signal if the slave address is correct. d) Master sends control register address (8-bit) e) Slave sends acknowledge signal f) Master generates STOP condition followed with START condition or REPEAT START condition g) Master device sends slave address (7-bit) and the data direction bit (R = 1). h) Slave device sends acknowledge signal if the slave address is correct. i) Slave sends data high 8Bit from addressed register. j) Master sends acknowledge signal k) Slave sends data low 8Bit from addressed register. l) If the master device sends acknowledge signal, the slave device will increase the control register address by one, then send the next data from the new addressed register. If master sends no acknowledge signal, the slave device stop to send data and wait for STOP condition. ic C o n fi d e a) in m) If the master device generates STOP condition, the read cycle is ended. SCL 0 SDA 1 A6 A5 w 0 …… a A6 1 A5 RS A4 4 A3 …… A2 2 3 A4 A3 4 A1 6 7 A2 8 0 A6 S 1 A5 2 A4 3 A3 A0 R/W Ack A7 1 A6 6 7 8 2 3 A5 A4 4 A3 5 A2 0 1 ... 6 7 D8 8 5 A1 2 I C Address 6 7 8 8 7 A1 A0 Ack 1 ... 6 Ack 0 D7 0 1 ... D6 …… D1 7 8 D0 Ack Register Data Low 8Bit Register Data High 8Bit 4 6 Register Address A0 R/W Ack D15 D14 …… D9 A1 A2 0 …… 5 6 A0 R/W Ack D15 D14 …… D9 7 8 0 D8 Ack D7 Register Data High 8Bit 1 ... Stop 6 D6 …… D1 Register Data Low 8Bit 7 D0 8 Ack Stop AW9109 I2C Read Timing Figure 11 www.awinic.com.cn 5 I2C Address Separated Read/write transaction …… P 3 I2C Address Start Using Repeat start…… 2 12 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 9.4 OSCILLATOR An internal oscillator provides clock for LED controlling circuit. If register bit GCR.LEDE is high, the OSC starts to work, the start-up time is about 5 μs. When both the register bit GCR.LEDE are low, the internal OSC stops. 9.5 LED DRIVER ti a l LED driver provide 9 current sources to drive LEDs, a dedicated Application-Specific-Processor(ASP)is designed to produce versatile lighting effect for mobile devices. ASP n If the control bit GCR.LEDE is 0 , LED driver circuit is in reset state, all 9 LED outputs are disabled. If control bit GCR.LEDE is 1, the LED driver circuit is enabled, the control bit LER.LENx (x=1 to 9) configure the corresponding LED channel is active or not. fi d PWM2 PWM Controller Program Controller ... ... LED1 LED2 ... LED9 o n PWM9 PWM Controller e PWM1 PWM Controller C I2C Interface Figure 12 9.5.1 SDA ic SCL AW9109 LED Dimming Control Module Diagram LED brightness controller in Pulse Width Modulation (PWM) is used to adjust the brightness of LED, 256 level brightness with 9bit resolution is adapted. The PWM frequency can be configured between 125Hz or 250Hz by control bit LCR.FREQ. w The ASP generates the PWM signal with dedicated and highly efficient dimming control instruction for all 9 independent LED constant current source. By programming, user-defined complicated lighting effect could be produced. a The LED control instruction executed by ASP could come from LED SRAM or external I2C register. The register CTRS can choose every LED channel to be controlled by SRAM program or by I2C register. - CTRS[n] = 0, LED n controller is controlled by the internal SRAM instruction; CTRS[n] = 1, LED n controller is controlled by the external I2C register. 9.5.2 LED Constant current driver For each LED, the maximum output constant current is 24.5mA, with 8 level adjustable by register IMAXn (n=1~9). www.awinic.com.cn 13 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 9.5.3 ASP ASP module is consist of one program controller and 9 PWM controllers. SCL Control Instruction PWM1 PWM Controller PWM2 PWM Controller PWM3 ti a PC PWM Controller n SRAM 256×16bits PWM Controller PWM9 fi d Figure 13 9.5.3.1 ... e ... Program_controller l SDA ASP Structure Diagram Program Controller C o n The program controller is clocked by 32kHz internal clock, each instruction is executed in one clock cycle. The program controller is consist of a program SRAM, an algorithmic logic unit ( ALU) and other internal registers. The 256x16bit internal SRAM is used to store LED lighting effect program loaded through I2C interface, the I2C interface also can start or stop the program execution. There are 4 internal registers RA/RB/RC/RD participating ALU operation so as to generate complicated program control such as repeating and looping. Except for that, there are 8 8bit temporary data registers(R1~R8) and 5 special function registers. Their internal address and function description is shown in the table below. Table 1 Address allocation of Address(HEX) R1 00 R1 data temporary register,8bit,I2C readable 01 R2 data temporary register,8bit,I2C readable 02 R3 data temporary register,8bit,I2C readable R4 03 R4 data temporary register,8bit,I2C readable R5 04 R5 data temporary register,8bit,I2C readable R6 05 R6 data temporary register,8bit,I2C readable R7 06 R7 data temporary register,8bit,I2C readable R8 07 R8 data temporary register,8bit,I2C reading GMSK1 GMSK2 0d 0e Global control mask register(M6~M1) Global control mask register(M9~M7) w in R3 ic Register R2 a internal data register in ASP Description Table 2 Special function registers definition Register B7 B6 B5 B4 B3 B2 B1 B0 Description GMSK1 M5 M4 M3 M2 M1 - - M9 M8 M7 Mask control for global control instruction. When Mn=1, LEDn will not be affected by global M6 GMSK2 www.awinic.com.cn 14 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 control instruction. 9.5.3.2 PWM Controller ti a l The PWM controller is execution unit of LED control instruction. There are 9 PWM controllers receiving the LED effect instruction from SRAM, and generate 8bit PWM code, which will be convert to 9bit duty cycle control code by logarithmic l transformation. If LCR.LOGLN=00, the transformation is natural logarithm( loge ). If LCR.LOGLN=01, the transformation is logarithm of 10 (log10 ), otherwise the 8b-to-9b transformation of PWM code is linear. SCL 8 log/lin PWM Generator fi d Register 9 LEDx e Cmd Execute From SRAM n SDA 3 PWM Controller Schematic Diagram o Figure 14 n 1MHz C 100 95 90 85 ic 80 75 LO LO IN G G =1 /L /L 0 IN IN =0 =0 0 1 65 a w in Brightness(%) 70 LO G /L 60 55 50 45 40 35 30 25 20 15 10 5 0 16 32 48 64 80 96 112 128 144 160 176 192 208 224 240 256 Control Signal Value(Decimal) www.awinic.com.cn 15 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Figure 15 9.5.3.3 a) 8bit-to-9bit PWM code transformation curve Program Loading and execution Program loading b) ti a l It is recommended to load SRAM program only when control bit PMD.PROGMD is 00. In this state, the internal program can be read/write through I2C interface. When loading program, please write the SRAM loading address in register WADDR(0x7E) at first, and then write the 16bit LED effect instruction to register WDATA(0x7F). Continuously loading program is supported, after a 16b instruction is written through register WDATA, the value of WADDR will automatically plus by 1. Program execution Register bit PMD.PROGMD[1:0] controls the loading and execution mode of SRAM program. n When register bit IPMD.PROGMD[1:0]=00, program execution is shut down, SRAM program and program pointer(PC) are permitted to be loaded. e When IPMD.PROGMD[1:0] is written to be 01 from another value, current program will stop , and PC will be reload by register SADDR, and then executes the SRAM program starting from the address of PC fi d When Register bit PMD.PROGMD[1:0] =10, the SRAM program will be executed by the mode defined by register bit RMD.RUNMD[1:0] Table 3 Program running mode control register RMD.RUNMD Hold mode. program stop and PC 01 Single step mode, only used for debugging. Once writing 01 to RUNMD, only one instruction will be executed with PC+1, and then RMD.RUMND is cleared (return to hold mode) 10 Continuously running mode, program starts from the address of 11 Repeating mode, only used for debugging. Once writing 11 to RUNMD, current instruction will be executed without PC+1, and then RMD.RUMND is cleared (return to hold mode) hold after one instruction is finished. C o n 00 PC. ic 9.5.3.4 Function Description SRAM program Instruction Table 4 LED Effect Instruction Command 15 14 13 12 11 10 9 8 JP 0 0 0 0 0 0 0 0 a w in There are 27 commands in ASP instruction set, including LED control command, data operation and transfer command, wait and branch control command. The Rx,Ry and Rz in instruction list means the internal register RA, RB, RC and RD, each of them can participate the ALU operation as source or destination register. NOP 0 0 0 0 0 0 0 1 ----- 0 0 0 0 0 0 1 X JPZ Addr 0 0 0 0 0 1 0 0 ADDR[7:0] JPNZ Addr 0 0 0 0 0 1 0 1 ADDR[7:0] JPS Addr 0 0 0 0 0 1 1 0 ADDR[7:0] JPNS Addr 0 0 0 0 0 1 1 1 ADDR[7:0] www.awinic.com.cn 16 7 6 5 4 3 2 1 0 - - - ADDR[7:0] - - - - - Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 0 0 0 0 1 0 Rz Im[7:0] CMPI Rz Im 0 0 0 0 1 1 Rz Im[7:0] ANDR Rz Im 0 0 0 1 0 0 Rz Im[7:0] ORR Rz Im 0 0 0 1 0 1 Rz Im[7:0] RDR Rz Addr 0 0 0 1 1 0 Rz ADDR[7:0] WDR Rz Addr 0 0 0 1 1 1 Rz ADDR[7:0] ADDI Rz Im 0 0 1 0 0 0 Rz Im[7:0] AUBI Rz Im 0 0 1 0 0 1 Rz Im[7:0] ADDR Rx Ry 0 0 1 0 1 0 Rz - - - - SUBR Rx Ry 0 0 1 0 1 1 Rz - - - - CMPR Rx Ry 0 0 1 1 0 0 0 0 - - - - ---- 0 0 1 1 0 0 X X END Int Rst 0 0 1 1 0 1 0 0 - - - INTN_MASKOFF 0 0 1 1 0 1 1 0 - - INTN_MASKON 0 0 1 1 0 1 1 1 - - WAITI Pre Time 0 0 1 1 1 Pre SETPWMR Rx Ry 0 1 0 0 0 0 RAMPR Dir Rx 0 1 0 0 0 0 SETSTEPTMRR Pre Rx Ry 0 1 0 0 0 1 SETSTEPTMRI Pre Ch Im 1 0 0 SETPWMI Ch Im 1 0 1 RAMPI Dir Ch Im 1 1 Dir Ry Rx Ry Rx Ry n Rx - - Int Rst - - - - - - - - - - - - fi d e - T[9:0] - - 0 0 0 Rx Ry 1 Dir - 0 0 0 Rx Ry 0 - Pre 0 0 0 Rx Ry Pre - n 0 o Ch[4:0] Im[5:0] Ch[4:0] Im[7:0] Ch[4:0] Im[7:0] C Ry ti a LD Rz Im l Feb. 2019 V1.4 a) Special LED Control Command There are 3 types of LED control command. SETPWM: RAMP: SETSTEP: set the brightness level (0~255)for specified LED channel; set the specified LED channel fade in or fade out for expected step( 0~255) set the fading slope for specified LED channel; ic - in All control parameter in above commands can either come from specified register (RA~RD), or from immediate data contained in command.. All LED control command supports broadcast mode, one instruction may send to multiple or all LEDs w When SRAM program running, if Ch field or value of Rx in LED control command is ‘11111’, the current command is active for all LED with setting of CTRSR.bitn=0. If Ch field or value of Rx in LED control command is ‘11110’, the current command is only active for those channel with setting of GMSKx=0. a When LED instruction is come from I2C interface directly, it is recommended to use only the command with immediate data. If the Ch field in command is “11111”, the current command is only active for those LED with STRSR.bitn=1.. Table 5 LED Control Instruction explanation Instruction www.awinic.com.cn Description 17 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Register Parameter SETPWMR Set the Fade-in/Fade-out for specified step with parameter in register Dir: 1: Fade-in; 0: Fade-out Rx: LED channel number, 2~10 for LED 1~ LED 9 respectively Ry: the step number of Fade-in/Fade-out Dir Rx Ry SETSTEPTMRR ti a l RAMPR Set the PWM brightness level with parameter in register Rx: LED channel number, 2~10 for LED 1~ LED 9 respectively Ry: Brightness level, 0~255 Rx Ry Set the RAMP slope with parameter in register Pre: basic time unit, 0: 0.5ms; 1: 16ms Rx: LED channel number, 2~10 for LED 1~ LED 9 respectively Ry: RAMP step time = (Ry+1)*Pre Pre Rx Ry n Immediate Data Set the PWM brightness level with immediate parameter Ch: LED channel number, 2~10 for LED 1~ LED 9 respectively Im: Brightness level, 0~255 RAMPI Dir Ch Im Set the Fade-in/Fade-out for specified steps with immediate parameter Dir: 1: Fade-in; 0: Fade-out Ch: LED channel number, 2~10 for LED 1~ LED 9 respectively Im: the steps of Fade-in/Fade-out SETSTEPTMRI Set the RAMP step time with immediate parameter Pre: basic unit of time, 0: 0.5ms; 1: 16ms Ch: LED channel number, 2~10 for LED 1~ LED 9 respectively Im: RAMP step time = (Im +1)*Pre, 0~63 fi d e SETPWMI Ch Im a w in ic C o n Pre Ch Im www.awinic.com.cn 18 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Table 6 Program Control and operation Instruction Instruction Encoding Description Addr 0x00xx Immediate Jump, jump to PC = Addr Addr 0x04xx Conditional Jump, If Rz is 0, jump to PC = Addr JPNZ Addr 0x05xx Conditional Jump, If Rz is not 0, jump to PC = Addr JPS Addr 0x06xx Conditional Jump, If Rz < 0, jump to PC = Addr JPNS Addr 0x07xx Conditional Jump, If Rz >= 0, jump to PC = Addr JPZ 0x08xx 0x0bxx Rz = Im RDR Rz Addr 0x18xx 0x1bxx Rz = *Addr WDR Rz Addr 0x1cxx 0x1fxx *Addr = Rz n Computation Instruction fi d LD Rz Im e n Data Transfer Instruction ti a JP l branch Instruction 0x0cxx 0x0fxx Rz – Im, only change S/Z flag CMPR Rx Ry 0x30xx Rx – Ry, only change S/Z flag ANDR Rz Im 0x10xx 0x13xx C o CMPI Rz Im ic Rz = Rz & Im, affect S/Z flag 0x14xx 0x17xx Rz = Rz | Im, affect S/Z flag 0x20xx 0x23xx Rz = Rz + Im, affect S/Z flag SUBI Rz Im 0x24xx 0x27xx Rz = Rz - Im, affect S/Z flag ADDR Rz Rx Ry 0x28xx 0x2bxx Rz = Rz + Ry, affect S/Z flag SUBR Rz Rx Ry 0x28xx 0x2bxx Rz = Rz - Ry, affect S/Z flag 0x34xx Program end with optionally reset register RMD and generate in ORR Rz Im a w ADDI Rz Im Control Instruction END Int Rst www.awinic.com.cn 19 interrupt Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Int= 0: no interrupt after instruction executed; Int= 1: generate interrupt after instruction executed Rst=0: PC add 1 after instruction executed; Rst=1: Reload PC with SADDR after instruction executed 0x36xx Unmask internal interrupt INTN_MASKON 0x37xx Mask internal interrupt WAITI Pre Time 0x38xx 0x3fxx Wait for specified time Pre: time of basic waiting cycle, 0: 0.5ms; 1: 16ms Time: number of waiting cycle, max value is 1023, wait time=Pre*Time ti a 9.6.3.5 l INTN_MASKOFF Example n PWM Value 255 256 384 512 640 768 Figure 16 896 Time (ms) 1024 1152 1280 1408 1536 1664 1792 1920 2048 2176 fi d 128 e LED1 128 LED Effect Programming Diagram Table 7 Reference Instruction of LED Effect Programming Machine Code explanation 0 SETSTEPTMRI 0x00 0x1F 0x03 0x9F03 RAMPI step time: 2ms 1 SETPWMI 0x1F 0x00 0xBF00 ALL LED turn off C START: n Assemble Instruction o PC Address Label “START” (01H) RAMPI 0x01 0x02 0x80 0xE280 LED1 fade in, 128 steps breath 3 WAITI 0x01 0x20 0x3C20 Wait 512ms 4 RAMPI 0x00 0x02 0x80 0xC280 LED1 fade out, 128 steps breath 5 WAITI 0x01 0x38 0x3C38 Wait 896ms 6 JP START 0x0002 Jump to START, PC=2 ic 2 in Step1: Power On, configure register a w  VBAT power on, 4.2V  Pull PDN to 3V  Wait 5ms  GCR = 0x0001  LER = 0x0004  IMAX1 = 0x0100  PMD.PROGRMD = 00  RMD.RUNMD = 00 Step2: Load Instruction to SRAM       WADDR = 0x0000 WDATA = 0x9F03 WDATA = 0xBF00 WDATA = 0xE280 WDATA = 0x3C20 WDATA = 0xC280 www.awinic.com.cn // enable LED module // enable LED1 // IMAX1 = 3.5mA //hold mode //hold mode // load program starting at address =0x0000 20 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4   WDATA = 0x3C38 WDATA = 0x0002 Step3: Run SADDR = 0x0000 RMD.RUNMD = 10 PMD.PROGMD = 01 // execution mode change to run mode, // start program from 0x0000 a w in ic C o n fi d e n ti a l    www.awinic.com.cn 21 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD REGISTER DESCRIPTION REGISTER CONFIGURATION 14 D14 0 0 13 D13 0 0 12 D12 0 0 11 D11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 IMAX2 IMAX6 0 0 0 0 0 TIER TIVEC ISR2 SADDR 0 0 0 0 0 0 0 0 0 0 0 0 0x60 PCR 0 0 0 0x61 0x62 0x63 0x64 0x65 0x66 ~ 0x6D 6E 7D 7E 7F CMDR RA RB RC RD R1 ~ R8 GRPR WP WADDR WDATA D15 0 0 0 0 D14 0 0 0 0 D13 0 0 0 0 0 0 0 - ic in w a www.awinic.com.cn 0 0 0 0 10 9 D10 D9 0 0 LED9 LED8 0 0 0 CS9 0 0 0 0 8 7 6 5 4 D8 D7 D6 D5 D4 0 0 0 0 0 LED7 LE6 LE5 LE4 LE3 RESERVED 0 SRMINI LIRMD TIMD 0 0 0 0 0 0 0 0 0 0 0 0 CS8 CS7 CS6 CS5 CS4 CS3 RESERVED IMAX1 0 IMAX5 0 IMAX4 IMAX9 0 IMAX8 n 15 D15 0 0 fi d e Register IDRST GCR LER LCR PROGMD RUNMD CTRS IMAX1 IMAX2 IMAX3 n Address 0x00 0x01 0x50 0x51 0x52 0x53 0x54 0x55 0x56 0x57 0x58 0x59 0x5a 0x5B 0x5C 0x5D 0x5E 0x5F o 10.1 TIE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 D12 0 0 0 0 D11 0 0 0 0 D10 0 0 0 0 D9 0 0 0 0 D8 0 0 0 0 D7 D6 D5 0 GS9 GS8 GS7 GS6 0 GS5 0 GS4 0 0 0 0 0 0 0 WPW 0 0 22 3 D3 0 LE2 2 D2 0 LE1 LIE 0 0 CS2 FREQ 0 0 CS1 1 D1 0 0 0 D0 LEDE 0 LOG/LIN PROGMD RUNMOD 0 0 0 IMAX3 IMAX7 0 0 RESERVED 0 0 0 0 C 10 ti a l AW9109 Feb. 2019 V1.4 0 CODE 0 0 TIVEC 0 0 SADDR PC D4 D3 RA RB RC RD R1 ~ R8 GS3 GS2` 0 0 ADDR 0 0 KIE 0 0 LIS D2 D1 D0 GS1 0 D1 0 D0 0 Copyright © 2015 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 10.2 GLOBAL REGISTER DESCRIPTION 10.2.1 IDRST, Chip ID and Software Reset 10.2.2 GCR, Global Control Register Address: 0x01, R/W, default: 0x0000 15 14 13 12 11 10 9 8 0 0 0 0 0 0 0 0 Bit Symbol Description 0 LEDE LED driver function 0: disable LED driver (default) 1: enable LED driver 6 0 5 0 4 0 3 0 1 D1 0 D0 2 0 1 0 0 LEDE 10.3 LED Effect Control Register 10.3.1 LER1, LED Driver Enable Register fi d e n 7 0 2 D2 l 12 11 10 9 8 7 6 5 4 3 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 Description Chip ID: 0xB223 Software Reset: write 0x55AA to IDRST, reset the whole device. ti a Address: 0x00, R/W 15 14 13 D15 D14 D13 Bit Symbol 15:0 IDRST 6 LE5 5 LE4 4 LE3 3 LE2 2 LE1 1 0 0 0 10.3.2 C o n Address: 0x50, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 0 0 0 0 0 LE9 LE8 LE7 LE6 Bit Symbol Description 1:0 Reserved, must be 0 10:2 LEx LED output enable 0: disable 1: enable 15:11 Reserved, must be 0 LCR, LED Effect Configuration Register a w in ic Address: 0x52, R/W, default: 0x0080 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 0 0 0 0 0 0 SRMINI LIRMD 0 LIE FREQ LOGLIN Bit Symbol Description 1:0 Log/Lin Log/Linear dimming mode selection 00: log dimming 1, log(e) (default) 01: log dimming 2, log10 1x: linear dimming 2 FREQ PWM frequency selection 0: 250Hz (default) 1: 125Hz 3 LIE LED program end interrupt enable 0: disable interrupt(default) 1: enable interrupt 5:4 Reserved 7:6 LIRMD LED effect code run mode after responding to interrupt request 00: hold mode, PC point can be changed, program hold and wait for RMD.RUNMD 01: step mode 10: run mode (default) 8 SRMINI SRAM reset bit, write 1, reset SRAM; read SRAM status, default is 0. 10.3.3 PMD, Program Mode Register Address: 0x53, R/W, default: 0x0000 15 14 13 12 11 10 9 www.awinic.com.cn 8 23 7 6 5 4 3 2 1 0 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 0 0 Symbol PROGMD 0 0 0 0 0 0 0 0 0 0 0 PROGMD Description Program control mode 00: load program via I2C interface (default) 01: re-load program and execute. When write 01 to PROGMD[1:0], set PC pointer will be updated with SADDR, then start to run program, and finally PROGMD[1:0] is changed to 10 automatically 10: run program. Under this mode, the control bit RUNMD in register RMD can configure different program running mode for normal operation or debug. 11: undefined 10.3.4 ti a l 0 Bit 1:0 RMD, Program Run Mode Register 10.3.5 fi d e n Address: 0x54, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 RUNMD Bit Symbol Description 1:0 RUNMD SRAM program run mode, only active for these LED set with CTRSR.CSx=0 00: hold mode, program stop and hold PC pointer (default) 01: step mode, RUNMD reset, PC+1 after the current program executed 10: run mode, normal program run 11: repeat mode, RUNMD reset, PC hold after the current program executed CTRSR, LED Control Source Selection Register 3 CS2 2 CS1 1 0 0 0 IMAX1~IMAX6, LEDx Maximum Output Current Register C 10.3.6 o n Address: 0x55, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 4 0 0 0 0 CS9 CS8 CS7 CS6 CS5 CS4 CS3 Bit Symbol Description 7:2 CSx LED control source 0: LEDx controlled by SRAM program 1: LEDx controlled by external MCU via I2C interface 6 5 IMAX4 IMAX8 4 0 3 0 2 1 0 IMAX3 IMAX7 w in ic Address: 0x57~0x59, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 0 IMAX2 0 IMAX1 0 IMAX6 0 IMAX5 0 0 0 0 0 IMAX9 Bit Symbol Description 10:8 IMAX1 LEDx maximum output current selection 14:12 IMAX2 000: 0mA (default) 2:0 IMAX3 001: 3.5mA 6:4 IMAX4 010: 7.0mA 10:8 IMAX5 011: 10.5mA 14:12 IMAX6 100: 14.0mA 2:0 IMAX7 101: 17.5mA 6:4 IMAX8 110: 21.0mA 10:8 IMAX9 111: 24.5mA LISR, LED Interrupt Status Register a 10.3.7 Address: 0x5E, R(clear by reading), default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 LIS Bit Symbol Description 1 LIS LED program end interrupt status, set by END instruction with parameter int=1, used for inform external MCU that program has finished. LCR.LIE is the enable bit for LIS. 0: no interrupt 1: interrupt request www.awinic.com.cn 24 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 10.3.8 SADDR, Program Start Address Register Address: 0x5F, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 4 3 2 0 0 0 0 0 0 0 0 SADDR Bit Symbol Description 7:0 SADDR SRAM program starting address. For reload and run mode, PMD.PROGMD=10, program will jump to PC=SADDR and run again. if PCR, LED Program Control Pointer Register 0 setting l 10.3.9 1 CMDR, LED Command Register Address: 0x61, R/W, default: 0x0000 15 14 13 12 11 10 7 CMD 6 5 4 3 2 1 0 fi d 10.3.11 8 Symbol CMD Description External controlled Command. used to send external LED command which is only active for those LED configured with control bit CTRSR.CSx=1. The external controlled command adapted the same instruction with internal ASP. RA/RB/RC/RD,LED Internal Program Register n Bit 15:0 9 e 10.3.10 n ti a Address: 0x60, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 0 0 0 0 0 0 0 PC Bit Symbol Description 7:0 PC SRAM program pointer(PC), can be written by I2C interface. For normal program execution, set the PC pointer at PMD.PROGMD= 00 mode at first, and then write PMD.PROGMD with 10. 2 1 0 10.3.12 ic C o Address: 0x62~0x65, R, default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 4 3 0 0 0 0 0 0 0 0 RA 0 0 0 0 0 0 0 0 RB 0 0 0 0 0 0 0 0 RC 0 0 0 0 0 0 0 0 RD Bit Symbol Description 7:0 RA/RB/RC/RD LED internal program register, read only, for debug usage. R1~R8, LED Internal Data Register 5 4 3 R1 R2 R3 R4 R5 R6 R7 R8 2 1 0 a w in Address: 0x66~0x6D, R, default: 0x0000 15 14 13 12 11 10 9 8 7 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Bit Symbol Description 7:0 LED internal data register, for debug usage. R1~R8 10.3.13 GRP, LED Group Operation Register Address: 0x6E, R, default: 0x0000 15 14 13 12 11 10 0 0 0 0 0 GS9 Bit Symbol Description www.awinic.com.cn 9 GS8 25 8 GS7 7 GS6 6 GS5 5 GS4 4 GS3 3 GS2 2 GS1 1 0 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 GS[8:0] WADDR, LED Program Loading Address Register Address: 0x7E, R/W, default: 0x0000 15 14 13 12 11 10 9 8 7 6 5 0 0 0 0 0 0 0 0 Bit Symbol Description 7:0 ADDR SRAM address for program access via I2C interface 10.3.16 2 WDATA, LED Program Loading Data Register Address: 0x7F, R/W, default: 0x0000 15 14 13 12 11 10 Symbol CODE 9 8 7 CODE 6 5 1 0 4 Description SARM data for program access via I2C interface 3 2 1 0 n Bit 15:0 3 ADDR e 10.3.15 4 l 10.3.14 LED channel selection for external group control command. GS[n]=0, LEDn is not included in external LED command with chan=0x1E; GS[n]=1, LEDn is included in external LED command with chan=0x1E; ti a 10:2 WPR, Writing Protection Register a w in ic C o n fi d Address: 0x7D, R/W, default: 0x5500 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 WPW 0 0 0 0 0 0 0 0 Bit Symbol Description 15:8 WPW writing protection control, If WPW=0x55, all register is writable, otherwise all register except for WPR is not allowed to be written. www.awinic.com.cn 26 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 11 TAPE AND REEL INFORMATION Carrier Tape(All Dimensions are in Millimeters) 11.2 PIN1 Direction ic C o n fi d e n ti a l 11.1 a w in User Direction of Feed www.awinic.com.cn 27 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 Reel fi d e n ti a l 11.3 Notes: n Material: polystyrene Flatness: maximum permissible 3mm All dimensions are in millimeters Surface resistivity: 105 to 1011 ohms/sq or less All unmarked tolerance: ±0.5 a w in ic C o i. ii. iii. iv. v. www.awinic.com.cn 28 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 12 PACKAGE DESCRIPTION PIN 1# DOT BY MARKING 1.650±0.050 Exp.DAP 3.000±0.050 PIN 1# IDENTIFICATION CHAMFER C0.300x45º TQFN-20L (3 X 3mm) 1.650±0.050 Exp.DAP ti a 3.000±0.050 0.400 Bsc 1.600 Ref. Note: All Dimensions are in Millimeters fi d e BOTTOM VIEW n 0.200±0.050 TOP VIEW 0.750±0.050 n 0.000-0.050 0.203 Ref. SIDE VIEW RECOMMENDED LAND PATTERN C o 13 l 0.400±0.050 ic 0.3 0.3 4X(0.825) 20X(0.5) a w in 4X(1.1) 20X(0.2) 16X(0.4) TOP VIEW Note:All Dimensions are in Millimeters www.awinic.com.cn 29 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 REFLOW Reflow Note Average ramp-up rate (217°C to peak) n fi d e n ti a l 14 Spec Max. 3°C /sec 60-120sec Time to be maintained above 217°C 60-150sec C o Time of Preheat temp. (from 150°C to 200°C) >260°C Time within 5°C of actual peak temp 20-40sec Ramp-down rate Max. 6°C /sec ic Peak Temperature Time from 25°C to peak temp Max. 8min in Package Reflow Standard Profile NOTE 1: All data are compared with the package-top temperature, measured on the package surface; a w NOTE 2: AW9109 adopted the Pb-Free assembly. www.awinic.com.cn 30 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 REVISION HISTORY Date Change Record V1.0 Sept. 2017 V1.1 June. 2018 V1.2 Sep. 2018 Officially Released Update the ordering information Add the recommended land pattern Update the electrical characteristics Update the reflow information Update the storage temperature V1.3 Nov. 2018 Update document description of AW9109 V1.4 Feb. 2019 Add power on procedure ti a l Vision a w in ic C o n fi d e n 15 www.awinic.com.cn 31 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW9109 Feb. 2019 V1.4 16 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. ti a l AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. e n AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. fi d Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. o n Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. C Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 32 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW9109QNR 价格&库存
很抱歉,暂时无法提供与“AW9109QNR”相匹配的价格&库存,您可以联系我们找货
