1000 Eaton Boulevard
Cleveland, OH 44122
United States
52U Heavy-Duty 4-Post SmartRack Open Frame
Rack - Organize and Secure Network Rack
Equipment
MODEL NUMBER: SR4POST52HD
Highlights
52U Heavy-Duty 4-post open
frame rack
Black steel with square,
numbered mounting holes
Toolless button holes to accept
PDUs or cable managers
Package Includes
Description
Tripp Lite's 52U Heavy-Duty 4-Post Open Frame Rack helps IT managers organize their equipment array
and provides fast, easy access to installed IT equipment. The SR4POST52HD is a simple solution for
housing IT equipment in secure environments and other areas that don't require a lockable rack solution.
This 52U rack features heavy-duty cold-rolled steel construction with a black powder-coated finish for
durability. It supports stationary loads up to 3000 lbs (1360.8 kgs). The SR4POST52HD comes with all the
hardware required for assembly and has a self-squaring design with bolt-down provisions. For highdensity applications, multiple units can be bolted together side by side.
The open design of the SR4POST52HD provides unobstructed airflow and easy access to equipment and
cabling. It has numbered, square-hole mounting positions for easy installation of standard 19-inch rack
equipment. The SR4POST52HD supports equipment depths up to 35 inches. This rack also
accommodates toolless button-hole mounting for vertical PDUs and cable managers.
The optional SRCASTERHDKIT Heavy-Duty Rolling Caster Kit adds mobility to the SR4POST52HD. The
rack supports rolling loads of 3000 lbs (1360.8 kgs). The SR4POST52HD also supports optional side
panels with the SR52SIDE4PHD, a set of two half-size side panels that add a finished look to end-of-row
racks in your data center.
Features
Weight capacity of 3000 lbs (1360.8 kgs) stationary
Supports equipment depths up to 35 inches
Textured, black powder coat finish
Heavy-duty cold-rolled steel construction
Numbered mounting positions
Bolt down provisions
Self-squaring design
Easy assembly
Optional SRCASTERHDKIT heavy-duty caster kit permits mobile use of 3000 lbs (1360.8 kgs) rolling
loads
Optional SR52SIDE4PHD side panels for end-of-the-row aesthetics
1/3
SR4POST52HD Heavy-Duty 4Post Open Frame Rack
Installation hardware
(2x) PDU/Cable management
brackets
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332185792
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
52U
Rack Depth
Standard
Maximum Device Depth (cm)
89.54
Maximum Device Depth (in.)
35.25
Maximum Device Depth (mm)
895
Shipping Dimensions (hwd / in.)
6.75 x 9.50 x 101.00
Shipping Dimensions (hwd / cm)
17.14 x 24.13 x 256.54
Shipping Weight (lbs.)
120.00
Shipping Weight (kg)
54.43
Unit Dimensions (hwd / in.)
97.000 x 24.000 x 35.250
Unit Dimensions (hwd / cm)
246.38 x 60.96 x 89.535
Unit Weight (lbs.)
116
Unit Weight (kg)
52.62
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Pre-Installed Casters
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; EIA/ECA-310-E
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
2/3
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR4POST52HD”相匹配的价格&库存,您可以联系我们找货
