SS52-520 SERIES
SCHOTTKY
SMB SS52
Plastic-Encapsulate
Schottky Barrier Diode
THRU SS520
SMB
ROHS
FEATURES
DO-214AA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
0.155(3.94)
0.130(3.3)
0.087 (2.21)
0.070 (1.80)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
MECHANICAL DATA
0.12(3.1)
0.11(2.82)
0.060(1.52)
0.030(0.76)
Case: JEDEC DO-214AA molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.005 ounce, 0.138 grams
0.008(0.203)MAX.
0.222(5.66)
0.194(4.93)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS SS52 SS53 SS54 SS55 SS56 SS58 SS510 SS515 SS520
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
5.0
Amps
IFSM
150.0
Amps
VF
0.45
IR
CJ
RqJA
TJ,
TSTG
0.55
-65 to +125
0.85
0.70
0.5
10
500
55.0
-65 to +150
-65 to +150
Volts
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.4x0.4”(10x10mm) copper pad areas
Rev 8: Nov 2014
www.born-tw.com
Page 1 of 2
SS52-520 SERIES
SCHOTTKY
SMB SS52
Plastic-Encapsulate
THRU SS520
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3
2
SS52-SS54
SS55-SS520
1
50
75
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
£PEAK FORWARD SURGE CURRENT,
AMPERES
5
100
125
150
120
90
60
30
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
10
AMBIENT TEMPERATURE, C
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1,000
1
TJ=25 C
PULSE WIDTH=300 ms
1%DUTY CYCLE
0.1
SS52-SS54
SS55-SS56
SS58-SS520
0.2
0.4
0.6
0.8
1.0
1.1
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
10
0.01
TJ=100 C
100
TJ=75 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
TJ=25 C
100
SS52-SS54
SS55-SS520
10
60
80
100
100
10
1
0.1
0.01
10
1.0
40
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
TRANSIENT THERMAL IMPEDANCE,
C/W
1000
0.1
PERCENT OF PEAK REVERSE VOLTAGE,%
2000
JUNCTION CAPACITANCE, pF
100
NUMBER OF CYCLES AT 60 Hz
1
10
100
100
REVERSE VOLTAGE,VOLTS
Rev 8: Nov 2014
ROHS
www.born-tw.com
t,PULSE DURATION,sec.
Page 2 of 2
很抱歉,暂时无法提供与“SS54”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.36300
- 20+0.33000
- 100+0.29700
- 500+0.26400
- 1000+0.24860
- 2000+0.23760
