TSM026NA03CR
Taiwan Semiconductor
N-Channel Power MOSFET
30V, 168A, 2.6mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive loss
PARAMETER
VALUE
UNIT
VDS
30
V
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
RDS(on)
VGS = 10V
2.6
(max)
VGS = 4.5V
3.3
mΩ
Qg
nC
en
de
d
41
APPLICATION
● DC-DC Converters
● Battery Power Management
● ORing FET/Load Switching
eco
mm
PDFN56
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
No
tR
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
TC = 25°C
(Note 1)
Pulsed Drain Current
(Note 2)
Single Pulsed Avalanche Current
(Note 2)
Single Pulsed Avalanche Energy
Total Power Dissipation
LIMIT
UNIT
VDS
30
V
VGS
±20
V
ID
TA = 25°C
SYMBOL
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
168
24
A
IDM
672
A
IAS
EAS
37
205
A
mJ
PD
PD
125
25
2.6
0.5
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
1
°C/W
Junction to Ambient Thermal Resistance
RӨJA
48
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is
determined by the user’s board design.
1
Version: B1610
TSM026NA03CR
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
30
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
1.2
1.65
2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
1
100
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 30V
TJ = 125°C
VGS = 10V, ID = 24A
(Note 3)
VGS = 4.5V, ID = 24A
Forward Transconductance
VDS = 5V, ID = 24A
gfs
(Note 4)
VGS = 10V, VDS = 15V,
Total Gate Charge
ID = 24A
Total Gate Charge
ID = 24A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 15V
Output Capacitance
f = 1.0MHz
Gate Resistance
Switching
e co
Reverse Transfer Capacitance
f = 1.0MHz
(Note 4)
tR
Turn-On Delay Time
Turn-On Rise Time
ID = 14A, RG = 10Ω,
Turn-Off Delay Time
1.9
2.6
2.5
3.3
68
RL = 1.07Ω
Turn-Off Fall Time
mΩ
S
Qg
41
Qg
21
Qgs
7
Qgd
6.5
Ciss
2540
Coss
600
Crss
200
Rg
0.2
0.8
1.6
td(on)
19.9
tr
12.3
td(off)
61.3
tf
18.0
VSD
1.2
V
mm
VGS = 4.5V, VDS = 15V,
Gate-Source Charge
en
Dynamic
(Note 3)
RDS(on)
de
Drain-Source On-State Resistance
µA
d
VGS = 0V, VDS = 30V
nC
pF
Ω
ns
No
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = 24A
Reverse Recovery Time
IS = 24A ,
trr
47
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
38
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = 10V, VDS = 25V, RG = 25Ω, IAS = 37A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
TSM026NA03CR RLG
PACKAGE
PACKING
PDFN56
2,500pcs / 13” Reel
2
Version: B1610
TSM026NA03CR
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
40
VGS=3V
24
16
8
32
24
25℃
d
32
16
de
VGS=10V
VGS=5V
VGS=4.5V
VGS=4V
VGS=3.5V
ID, Drain Current (A)
40
8
150℃
1
1.5
2
2.5
2
3
4
Gate-Source Voltage vs. Gate Charge
mm
On-Resistance vs. Drain Current
0.004
0.0035
0.003
VDS=15V
ID=24A
8
6
e co
VGS=4.5V
VGS, Gate to Source Voltage (V)
10
0.0025
0.002
VGS=10V
0.0015
0.001
tR
RDS(ON), Drain-Source On-Resistance (Ω)
1
VDS, Drain to Source Voltage (V)
8
16
24
32
4
2
No
On-Resistance vs. Junction Temperature
RDS(on), Drain-Source On-Resistance (Ω)
1.6
1.4
1.2
1
VGS=10V
ID=24A
0.6
-75
-50
-25
50
75
30
40
50
On-Resistance vs. Gate-Source Voltage
1.8
0.8
Qg, Gate Charge (nC)
(Normalized)
-55℃
en
0.01
0.008
0.006
0.004
ID=24A
0.002
4
5
6
7
8
9
10
TJ, Junction Temperature (°C)
3
Version: B1610
TSM026NA03CR
BVDSS vs. Junction Temperature
CISS
2000
1500
1000
COSS
500
0.8
10
15
30
-75
-50
-25
50
75
100 125 150
Source-Drain Diode Forward Current vs. Voltage
mm
Maximum Safe Operating Area, Junction-to-Case
RDS(ON)
150℃
25℃
10
e co
100
IS, Reverse Drain Current (A)
100
1000
10
SINGLE PULSE
RӨJC=1°C/W
TC=25°C
1
0.1
tR
1
en
CRSS
ID=5mA
1.1
d
C, Capacitance (pF)
2500
1.2
de
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
3000
1
10
-55℃
1
0.1
100
0.2
0.4
0.6
0.8
1
1.2
No
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=1°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.001
0.00001
0.0001
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.001
0.01
0.1
t, Square Wave Pulse Duration (sec)
4
Version: B1610
TSM026NA03CR
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
mm
en
de
d
PDFN56
No
tR
e co
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSC
026NA03
GYWWF
G
Y
WW
F
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
5
Version: B1610
TSM026NA03CR
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: B1610
