RU30L30M
RU30L30M
    VBSEMI(微碧)
    DFN8_3X3MM_EP
    MOS管 P-Channel VDS=30V VGS=±20V ID=14.4A RDS(ON)=18mΩ@4.5V DFN8_3X3MM_EP
RU30L30M 数据手册
RU30L30M www.VBsemi.com P-Channel 30 V (D-S) MOSFET VDS RDS(on),typ RDS(on),typ ID VGS=10V VGS=4.5V -30 V 11 18 -45 mΩ mΩ A FEATURES • Halogen-free According to IEC 61249-2-21 Definition • TrenchFET® Power MOSFET • Low Thermal Resistance PowerPAK® Package with Small Size and Low 1.07 mm Profile • 100 % Rg and UIS Tested • Compliant to RoHS Directive 2002/95/EC APPLICATIONS • Load Switch • Adaptor Switch • Notebook PC DFN 3x3 EP S Bottom View Top View Top View G 1 8 2 7 3 6 4 5 D P-Channel MOSFET Pin 1 ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted) Parameter Drain-Source Voltage Gate-Source Voltage Symbol VDS VGS TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C Continuous Drain Current (TJ = 150 °C) ID IDM Pulsed Drain Current Continuous Source-Drain Diode Current TC = 25 °C TA = 25 °C IS Avalanche Current Single-Pulse Avalanche Energy L = 0.1 mH IAS EAS Maximum Power Dissipation TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C PD Operating Junction and Storage Temperature Range c, d TJ, Tstg Soldering Recommendations (Peak Temperature) Notes: a. Surface mounted on 1" x 1" FR4 board. b. t = 10 s. c.Rework conditions: manual soldering with a soldering iron is not recommended for leadless components. d.Package limited. e.Based on T C = 25 °C Limit - 30 ± 20 Unit V - 45 - 30 - 14.4a, b - 11.5a, b - 60 - 35e - 3.2a, b - 25 31.25 52 A mJ 43 3.8a, b 2.4a, b - 50 to 150 260 W °C 1 RU30L30M www.VBsemi.com THERMAL RESISTANCE RATINGS Parameter Symbol RthJA RthJC t ≤ 10 s Steady State Maximum Junction-to-Ambienta, b Maximum Junction-to-Case (Drain) Typical 26 1.9 Maximum 33 2.4 Unit °C/W Notes: a. Surface mounted on 1" x 1" FR4 board. b. Maximum under Steady State conditions is 81 °C/W. SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) Parameter Symbol Test Conditions Min. Static Drain-Source Breakdown Voltage VDS Temperature Coefficient VDS VGS = 0 V, ID = - 250 µA - 30 ΔVDS/TJ VGS(th) Temperature Coefficient ΔVGS(th)/TJ Gate-Source Threshold Voltage Typ. Max. V - 20 ID = - 250 µA Unit mV/°C 5 VGS(th) VDS = VGS, ID = - 250 µA - 2.8 V Gate-Source Leakage IGSS VDS = 0 V, VGS = ± 20 V ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = - 30 V, VGS = 0 V VDS = - 30 V, VGS = 0 V, TJ = 55 °C - 10 On-State Drain Currenta ID(on) Drain-Source On-State Resistancea RDS(on) Forward Transconductancea Dynamicb Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd gfs Rg Gate Resistance VDS ≤ - 5 V, VGS = - 10 V VGS = - 10 V, ID = - 14.4 A tr Rise Time Fall Time Turn-On Delay Time VDS = - 15 V, ID = - 14.4 A 18 37 VDS = - 15 V, VGS = 0 V, f = 1 MHz 2000 385 a Pulse Diode Forward Current Body Diode Voltage S pF 322 15 VDS = - 15 V, VGS = - 10 V, ID = - 14.4 A 14 VDS = - 15 V, VGS = - 4.5 V, ID = - 14.4 A f = 1 MHz VDD = - 15 V, RL = 1.5 Ω ID ≅ - 10 A, VGEN = - 4.5 V, Rg = 1 Ω 0.4 1.8 7 9 3.6 50 75 65 tf 14 21 td(on) 14 21 VDD = - 15 V, RL = 1.5 Ω ID ≅ - 10 A, VGEN = - 10 V, Rg = 1 Ω tf Fall Time Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current mΩ 45 td(off) IS 9 18 36 54 10 20 - 35e - 60 TC = 25 °C ISM VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb µA A 11 43 tr Rise Time Turn-Off DelayTime - 20 30 td(off) Turn-Off DelayTime -1 VGS = - 4.5 V, ID = - 11.5 A td(on) Turn-On Delay Time - 1.5 IF = - 10 A IF = - 10 A, dI/dt = 100 A/µs, TJ = 25 °C nC Ω ns A - 0.8 - 1.2 V 31 47 ns 30 45 nC 15 16 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 RU30L30M www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 60 1.2 VGS = 10 V thru 5 V 0.9 ID - Drain Current (A) ID - Drain Current (A) 45 4V 30 125 ºC 0.6 25 ºC 15 0.3 - 55 ºC 0 0.0 3 6 9 15 12 0 1 2 3 4 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 0.030 3600 0.025 3000 C - Capacitance (pF) RDS - On-Resistance (mΩ) 0 0.020 VGS = 4.5 V 0.015 VGS = 10 V 0.010 Ciss 2400 1800 1200 0.005 600 0.000 0 Coss Crss 0 10 20 40 30 50 0 60 6 12 18 24 30 VDS - Drain-Source Voltage (V) ID - Drain Current (A) Capacitance On-Resistance vs. Drain Current and Gate Voltage 10 1.8 RDS(on) - On-Resistance (normalized) VGS - Gate-to-Source Voltage (V) ID = 14.4 A 8 VDS = 15 V, ID = 14.4 A 6 4 VDS = 24 V, ID = 14.4 A 2 0 0 10 20 30 40 50 1.5 VGS = 10 V 1.2 VGS = 4.5 V 0.9 0.6 - 50 - 25 0 25 50 75 100 125 150 Qg - Total Gate Charge (nC) TJ - Junction Temperature (ºC) Gate Charge On-Resistance vs. Junction Temperature 3 RU30L30M www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 0.04 RDS(on) - Drain-to-Source On-Resistance (Ω) IS - Source Current (A) 100 TJ = 150 ºC 10 TJ = 25 ºC 1 0.1 0.0 0.03 0.02 TJ = 125 ºC 0.01 TJ = 25 ºC 0.00 0.2 0.4 0.6 0.8 1.0 1.2 VSD - Source-to-Drain Voltage (V) 6 8 10 12 14 16 VGS - Gate-to-Source Voltage (V) Source-Drain Diode Forward Voltage On-Resistance vs. Gate-to-Source Voltage 0 2 4 18 20 50 2.4 ID = 250 µA 2.2 40 Power (W) 1.8 30 20 1.6 10 1.4 1.2 - 50 - 25 0 25 50 75 100 125 0 0.01 150 0.1 TJ - Temperature (ºC) 1.0 10 100 1000 Time (s) Single Pulse Power, Junction-to-Ambient Threshold Voltage 100 Limited by RDS(on)* 100 µs 10 ID - Drain Current (A) VGS(th) (V) 2.0 1 ms 10ms 1 100 ms 1s 10 s 0.1 TA = 25 ºC Single Pulse 0.01 0.1 DC BVDSS Limited 1 10 10 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is Specified Safe Operating Area, Junction-to-Ambient 4 RU30L30M www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 60 ID - Drain Current (A) 50 40 30 20 10 0 0 25 50 75 100 125 150 TC - CaseTemperature (°C) Current Derating* 75 2 60 Power (W) Power (W) 1.5 45 30 1 0.5 15 0 0 0 25 50 75 100 125 150 0 25 50 75 100 125 TC - Case Temperature (ºC) TA - Ambient Temperature (ºC) Power, Junction-to-Case Power, Junction-to-Ambient 150 * The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. 5 RU30L30M www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 Notes: 0.1 PDM 0.05 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = RthJA = 50 °C/W 0.02 3. TJM - TA = PDMZthJA(t) Single Pulse 0.01 10 -4 10 -3 10 -2 4. Surface Mounted 10 -1 1 Square Wave Pulse Duration (s) 10 100 1000 Normalized Thermal Transient Impedance, Junction-to-Ambient 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10 -4 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Case 6 RU30L30M www.VBsemi.com 7 RU30L30M www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. 8
RU30L30M 价格&库存
很抱歉,暂时无法提供与“RU30L30M”相匹配的价格&库存,您可以联系我们找货
RU30L30M
  • 1+3.18835
  • 10+2.87980
  • 50+2.63296
  • 150+2.46840
  • 300+2.36555
库存:133
