NDT2955
P-CHANNEL MOSFET FOR SWITCHING
10
6.50±0.2
3.00±0.1
Low on-resistance
High speed switching
Low drive current
4 V gate drive device can be driven from 5 V source
Suitable for switching regulator, DC-DC converter
D
1
3
0.250
1.6 ± 0.1
JS
G
2
0.75 (min)
7.0±0.3
3.50±0.2
4
2.30 (typ)
0.84 (max)
MI
0.02 ~ 0.1
1.Gate
2.Drain
3.Source
4.Drain
4.60 (typ)
S
CR
Absolute Maximum Ratings
(Ta = 25°C)
Drain peak current
Body to drain diode reverse drain current
Value
–60
Unit
V
VGSS
ID
±20
–3
V
A
ID (pulse)
IDR
–4
–1
A
A
1
150
W
°C
–55 to +150
°C
Se
Gate to source voltage
Drain current
Symbol
VDSS
mi
O
Item
Drain to source voltage
Gauge Plane
0.66 (min)
1.80 (max)
Unit:mm
SOT-223
Features
Channel dissipation
Channel temperature
Pch
Tch
Tstg
Electrical Characteristics
co
Storage temperature
Symbol
V (BR) DSS
Min
–60
Typ
Gate to source breakdown voltage
Gate to source leak current
V (BR) GSS
IGSS
±20
Zero gate voltage drain current
Gate to source cutoff voltage
IDSS
VGS (off)
–1.0
Static drain to source on state resistance
RDS (on)
RDS (on)
0.15
0.19
Forward transfer admittance
Input capacitance
|yfs|
Ciss
0.6
1.0
160
Output capacitance
Reverse transfer capacitance
Coss
Crss
Turn-on delay time
Rise time
td (on)
tr
Turn-off delay time
Fall time
Body to drain diode forward voltage
Body to drain diode reverse recovery time
(Ta = 25°C)
Max
Unit
V
Test Conditions
ID = –10 mA, VGS = 0
±5
V
µA
IG = ±100 µA, VDS = 0
VGS = ±16 V, VDS = 0
–10
–2.25
µA
V
VDS = –50 V, VGS = 0
ID = –1 mA, VDS = –10 V
0.17
0.2
Ω
Ω
ID = –0.5 A, VGS = –10 V
Note 3
ID = –0.5 A, VGS = –4 V
S
pF
80
28
pF
pF
ID = –0.5 A, VDS = –10 V
VDS = –10 V
VGS = 0
f = 1 MHz
7
8
ns
ns
td (off)
tf
30
25
ns
ns
VDF
trr
–1.1
90
V
ns
r
to
uc
nd
Item
Drain to source breakdown voltage
www.jsmsemi.com
Note 3
Note 3
ID = –0.5 A
VGS = –10 V
RL = 60 Ω
IF = –1 A, VGS = 0
IF = –1 A, VGS = 0
diF/dt = 50 A/µs
第1/4页
NDT2955
Main Characteristics
Power vs. Temperature Derating
Maximum Safe Operation Area
–5
–3
µs
10
ID (A)
10
0.5
pe
O
1.0
C
D
Drain Current
–0.3
–0.1
Operation in
this area is
limited by RDS (on)
–0.03
–0.01
50
100
150
MI
Ambient Temperature
Ta = 25°C
–0.005
–0.1 –0.3
–1
200
Ta (°C)
CR
–0.8
–2.5 V
VGS = –2 V
–2
–4
–6
Drain to Source Voltage
–8
–10
VDS (V)
Drain to Source Saturation Voltage vs.
Gate to Source Voltage
–1.0
Pulse Test
–0.8
ID = –1 A
–0.6
–0.5 A
–0.4
–0.2
–0.2 A
–2
–4
–6
–8
–10
Tc = 75°C
–0.4
25°C
–25°C
–0.2
r
to
uc
nd
–0.8
co
–0.4
VDS (V)
–0.6
mi
Drain Current
–1.2
ID (A)
–3 V
Drain Current
–1.6
–100
VDS = –10 V
Pulse Test
–1
–2
–3
–4
–5
VGS (V)
Static Drain to Source on State Resistance
vs. Drain Current
RDS (on) (Ω)
–6 V
–4 V
–30
–1.0
Pulse Test
Se
ID (A)
–10 V
–10
Typical Transfer Characteristics
O
–2.0
–3
Typical Output Characteristics
Drain to Source Saturation Voltage VDS (on) (V)
t)
µs
ho
s
10 ms s (1
n
m
1
tio
ra
–1
PW
1.5
JS
Channel Dissipation Pch (W)
(on the alumina ceramic board)
2.0
5
Pulse Test
2
VGS = –4 V
1
0.5
–10 V
0.2
0.1
0.05
–0.05 –0.1 –0.2
VGS (V)
www.jsmsemi.com
–0.5
Drain Current
–1
–2
–5
ID (A)
第2/4页
NDT2955
Forward Transfer Admittance |yfs| (S)
Forward Transfer Admittance vs.
Drain Current
2.0
Pulse Test
1.6
ID = –1 A
–0.5 A, –0.2 A
1.2
VGS = –4 V
–1 A
0.8
–0.5 A, –0.2 A
–10 V
0.4
JS
RDS (on) (Ω)
vs. Temperature
–40
80
120
MI
Case Temperature
160
5
2
Tc = –25°C
1
25°C
0.5
75°C
0.2
0.1
VDS = –10 V
Pulse Test
0.05
–0.01 –0.02
Tc (°C)
CR
IDR (A)
–40
–8
VDS
–60
VGS
–12
VDD = –10 V
–25 V
–40 V
–16
–80
ID = –1 A
–100
8
Gate Charge
12
16
–20
VGS (V)
–4
VDS (V)
–20
Crss
10
VGS = 0
f = 1 MHz
–10
–20
–30
–40
–50
Switching Characteristics
VDD = –10 V
–25 V
–40 V
30
Drain to Source Voltage VDS (V)
Dynamic Input Characteristics
Coss
1
–2
500
Switching Time t (ns)
Reverse Drain Current
–1
100
r
to
uc
nd
–0.5
Ciss
3
di / dt = 50 A / µs
VGS = 0, duty ≤ 1 %
10
5
–0.02 –0.05 –0.1 –0.2
Capacitance C (pF)
50
300
co
mi
Reverse Recovery Time trr (ns)
1000
Se
100
–1
Typical Capacitance vs.
O
200
–0.5
Drain Current ID (A)
Body-Drain Diode Reverse
Recovery Time
500
–0.05 –0.1 –0.2
VGS = –10 V, VDD = –30 V
PW = 2 µs, duty ≤ 1 %
200
100
50
tf
td(off)
5
–0.01 –0.02
Qg (nc)
www.jsmsemi.com
tr
td(on)
–0.05 –0.1 –0.2
Drain Current
–0.5
–1
ID (A)
第3/4页
NDT2955
Reverse Drain Current vs.
Source to Drain Voltage
Pulse Test
–0.8
–10 V
–0.6
–5 V
–0.4
–0.2
VGS = 0, 5 V
–0.4
–0.8
–1.2
–1.6
VSD
–2.0
(V)
O
CR
MI
JS
Reverse Drain Current IDR (A)
–1.0
Switching Time Test Circuit
Waveform
D.U.T.
RL
50 Ω
VDD
= –30 V
10%
90%
90%
90%
10%
10%
r
to
uc
nd
co
Vin
–10 V
Vin
mi
Se
Vout
Monitor
Vin Monitor
Vout
td(on)
www.jsmsemi.com
tr
td(off)
tf
第4/4页
很抱歉,暂时无法提供与“NDT2955”相匹配的价格&库存,您可以联系我们找货
