C2D10120A
VRRM VRRM=
1200
= 1200
V V
Silicon Carbide Schottky Diode
Zero R
ecovery®
Rectifier
Features
IF (TC=135˚C)
= 14.5
A
IF = 10
A
Qc
nC
61 nC
Qc == 61
Package
1.2kV Schottky Rectifier
Zero Reverse Recovery Current
Zero Forward Recovery Voltage
High-Frequency Operation
Temperature-Independent Switching Behavior
Extremely Fast Switching
Positive Temperature Coefficient on VF
TO-220-2
Benefits
Replace Bipolar with Unipolar Rectifiers
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
PIN 1
CASE
PIN 2
Applications
Switch Mode Power Supplies
Power Factor Correction
Motor Drives
Part Number
Package
Marking
C2D10120A
TO-220-2
C2D10120
Maximum Ratings (TC=25°C unless otherwise specified)
Symbol
Parameter
Test Conditions
VRRM
Repetitive Peak Reverse Voltage
1200
V
VRSM
Surge Peak Reverse Voltage
1200
V
VDC
DC Blocking Voltage
1200
V
Continuous Forward Current
31
14.5
10
A
TC=25˚C
TC=135˚C
TC=152˚C
50
A
TC=25˚C, tP=10 ms, Half Sine Wave
IF
IFRM
Repetitive Peak Forward Surge Current
IFSM
Non-Repetitive Peak Forward Surge Current
250
A
TC=25˚C, tP=10 µs, Pulse
Ptot
Power Dissipation
312
135
W
TC=25˚C
TC=110˚C
-55 to
+175
˚C
1
8.8
Nm
lbf-in
TJ , Tstg
Operating Junction and Storage Temperature
TO-220 Mounting Torque
1
Value Unit
C2D10120 Rev. F
M3 Screw
6-32 Screw
Note
Electrical Characteristics
Symbol
Parameter
Typ.
Max.
Unit
Test Conditions
VF
Forward Voltage
1.6
2.5
1.8
3.0
V
IR
Reverse Current
10
1000
µA
VR = 1200 V TJ=25°C
VR = 1200 V TJ=150°C
QC
Total Capacitive Charge
61
nC
VR = 1200 V, IF = 10 A
di/dt = 500 A/µs
TJ = 25°C
C
Total Capacitance
1000
80
59
pF
VR = 0 V, TJ = 25°C, f = 1 MHz
VR = 200 V, TJ = 25˚C, f = 1 MHz
VR = 400 V, TJ = 25˚C, f = 1 MHz
Note
IF = 10 A TJ=25°C
IF = 10 A TJ=175°C
Note:
1. This is a majority carrier diode, so there is no reverse recovery charge.
Thermal Characteristics
Symbol
Parameter
Typ.
Unit
RθJC
Thermal Resistance from Junction to Case
0.48
°C/W
18
180
16
160
14
140
IR Reverse Current (μA)
IF Forward Current (A)
Typical Performance
12
10
8
6
100
80
60
4
40
2
2.0
3.0
4.0
VF Forward Voltage (V)
Figure 1. Forward Characteristics
2
120
C2D10120 Rev. F
5.0
1000
1500
VR Reverse Voltage (V)
Figure 2. Reverse Characteristics
2000
C2D10120
Typical Performance
100
100.0
350
325
90.0
90
300
60.0
60
50
50.0
PTot (W)
70.0
70
275
Duty*
Duty*
Duty*
Duty*
Duty*
Power Dissipation (W)
10%
20%
30%
50%
70%
DC
(A)
Current
Forward
IIF(PEAK) Peak
(A)
Current
Forward
40
40.0
30
30.0
F(AVG)
250
225
200
175
150
125
100
75
50
10
10.0
25
25
25
50
50
75
75
100
100
125
125
150
150
175
25
50
Case
Temperature(°C)
TC Case
Temperature
75
100
125
Tc Case Temperature (°C)
TC ˚C
* Frequency > 1KHz
Figure 3. Current Derating
Figure 4. Power Derating
Page 1
800
700
600
C Capacitance (pF)
Peak Forward Current
80
80.0
500
400
300
200
100
10
100
Figure 5. Capacitance vs. Reverse Voltage
3
C2D10120 Rev. F
1000
150
175
Figure 6. Transient Thermal Impedance
4
C2D10120 Rev. F
Package Dimensions
POS
Package TO-220-2
A
J
C
P
F
Q
B
D
X
S
E
Y
1 2
G
Z
T
U
H
V
L
M
W
N
Inches
Millimeters
Min
Max
Min
Max
A
.381
.410
9.677
10.414
B
.235
.255
5.969
6.477
.120
2.540
M illim eters
M in
M5.664
ax
.337
3.048
C
P OS
D
A
E
B
F
C
GD
.395
.410
.590
.235
.255
.143
.102
.112
1.105
.337
.337
10.033
.615
5.969
.153
2.591
1.147
8.560
10.414
14.986
6.477
3.632
2.845
28.067
8.560
HE
.590.500 .610
.550
14.986
12.700
15.494
L F
G
M
H
N
J
P L
.149.025 .153
1.127
1.147
.045
.530
.550
.195
R 0.010
.028.165 .036
3.785
3.886
.036
.635
28.626 29.134
.055
1.143
13.462 13.970
.205
4.953
R 0.254
.185
4.191
.711
.914
QM
.045.048 .055
1.143
.054
S N
P
T
Q
US
.195 3°
.205
.170
.180
V T
WU
V
X
W
Y
X
zY
.100
Inc hes
M in.223 M ax
.048
3°
3° 3°
3°.094
.054
5°
5°
3°.014 5°
.100
.110
3°
.014
.021
.385
3°
5°
.395.130 .410
4.953
6°
4.318
6°
1.219
6°3°
1.397
1.219
5.207
3°
4.572
3°
1.371
5°3°
.110
3°
3°
.025
2.54
5.5°
.356
.410
3°
.150
10.033
2.388
5°
5°
.356
2.794
3°
.533
9.779
5°
3.302
10.414
8.560
15.621
3.886
29.134
13.970
.914
1.397
5.207
4.699
1.372
6°
6°
6°
2.794
.635
5.5°
10.414
3.810
.130
.150
3.302
3.810
NOTE:Z
1. Dimension L, M, W apply for Solder Dip
Finish
Recommended Solder Pad Layout
TO-220-2
Part Number
Package
Marking
C2D10120A
TO-220-2
C2D10120
Note: Recommended soldering profiles can be found in the applications note here:
http://www.cree.com/power_app_notes/soldering
5
C2D10120 Rev. F
Notes
• RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred
to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance
with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can
be obtained from your Cree representative or from the Product Documentation sections of www.cree.com.
• REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable
future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration.
REACh banned substance information (REACh Article 67) is also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into
the human body nor in applications in which failure of the product could lead to death, personal injury or property
damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines,
cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control
systems, air traffic control systems, or weapons systems.
Copyright © 2013 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
6
C2D10120 Rev. F
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
很抱歉,暂时无法提供与“C2D10120A”相匹配的价格&库存,您可以联系我们找货
