P1
TAI-TECH
HPC3015TF-SERIES
Power Inductor
ECN HISTORY LIST
REV
DATE
1.0
14/04/14
DESCRIPTION
新 發 行
備
註
www.tai-tech.com.tw
APPROVED
CHECKED
DRAWN
楊祥忠
詹偉特
羅文鍵
P2
TAI-TECH
HPC3015TF-SERIES
Power Inductor
1. Features
1. This specification applies Low Profile Power Inductors.
2. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
2. Dimension
Series
A(mm)
B(mm)
C(mm)
D(mm)
E(mm)
HPC3015TF
3.0±0.2
3.0±0.2
1.5 max.
1.0 ref.
1.0 ref.
Halogen
Pb
Halogen-free
Pb-free
Units: mm
3. Part Numbering
4.
HPC
3015
TF
A
B
C
2R2
M
D
E
A: Series
B: Dimension
C: Lead Free
D: Inductance
2R2=2.2uH
E: Inductance Tolerance
M=±20%; Y=±30%
TAI-TECH
Inductance Tolerance Test Frequency
Specification
Part Number
(uH)
(Hz)
SRF
(MHz) min.
DCR
(Ω) ±20%
I sat
(A)typ
I rms
(A)typ
HPC3015TF-1R0Y
1.0
±30%
1V100K
100
0.030
2.20
2.20
HPC3015 TF -1R5Y
1.5
±30%
1V100K
87
0.040
2.00
2.00
HPC3015 TF -2R2M
2.2
±20%
1V100K
64
0.060
1.70
1.70
HPC3015 TF -3R3M
3.3
±20%
1V100K
49
0.080
1.40
1.40
HPC3015 TF -4R7M
4.7
±20%
1V100K
40
0.120
1.20
1.20
HPC3015 TF -6R8M
6.8
±20%
1V100K
36
0.160
1.00
1.00
HPC3015 TF -100M
10
±20%
1V100K
28
0.220
0.75
0.80
HPC3015 TF -150M
15
±20%
1V100K
23
0.320
0.65
0.70
HPC3015 TF -220M
22
±20%
1V100K
0.55
0.60
HPC3015 TF -330M
33
±20%
1V100K
18
0.800
0.40
0.45
HPC3015 TF -470M
47
±20%
1V100K
17
1.200
0.35
0.40
Note:
Isat:Based on inductance change (△L/L0:≦-30%)@ ambient temp. 25℃
Irms:Based on temperature rise (△T:40℃ )
www.tai-tech.com.tw
P3
TAI-TECH
HPC3015TF-1R0
2
HPC3015TF-1R5
2.5
2
Inductance(uH)
Inductance(uH)
1.5
1
1.5
1
0.5
0.5
1
1.5
2
DCcurrent(A)
0.5
1.5
2
HPC3015TF-3R3
4
6
3
4.5
Inductance(uH)
Inductance(uH)
HPC3015TF-2R2
2
1
3
1.5
1
1.5
2
DCcurrent(A)
0.6
0.9
1.2
1.5
DCcurrent(A)
HPC3015TF-4R7
HPC3015TF-6R8
8
12
6
9
Inductance(uH)
Inductance(uH)
1
DCcurrent(A)
4
2
6
3
0.6
0.9
1.2
DCcurrent(A)
0.2
0.4
0.6
0.8
1
0.8
1
DCcurrent(A)
HPC3015TF-100
HPC3015TF-150
Inductance(uH)
Inductance(uH)
15
10
15
10
5
5
0.4
0.6
DCcurrent(A)
0.8
1
www.tai-tech.com.tw
0.2
0.4
0.6
DCcurrent(A)
P4
TAI-TECH
HPC3015TF-220
40
45
Inductance(uH)
30
Inductance(uH)
HPC3015TF-330
60
30
15
0.3
0.45
0.6
DCcurrent(A)
HPC3015TF-470
Inductance(uH)
60
40
0.2
0.3
0.2
0.3
DCcurrent(A)
80
0.4
0.5
DCcurrent(A)
www.tai-tech.com.tw
0.4
0.5
P5
TAI-TECH
Void appearance tolerance Limit
Exposed
wire tolerance
Size of voids occurring to coating resin
is specified
below. limit of coating resin part on product side.
Size of exposed wire occurring to coating resin is specified below.
1. Width direction(dimension a):Acceptable when a≦w/2
Nonconforming when a>w/2
:Dimension b is not specified.
2. Length direction(dimension b)
3. The total area of exposed wire occurring to each sides is
not greater than 50% of coating resin area, and is acceptable.
External appearance criterion for exposed wire
Exposed end of the winding wire at the secondary side should be 2mm and below.
6. Material
No.
Description
Specification
a.
Core
Ferrite Core
b.
Coating
Epoxy
c
Termination
Tin (Pb Free)
d
Wire
Enameled Copper Wire
www.tai-tech.com.tw
P6
TAI-TECH
7. Reliability and Test Condition
Item
Operating Temperature
Performance
Test Condition
-55~+125℃(For products in unopened tape package, less than 40℃)
Electrical Performance Test
Inductance L
Agilent-4291, Agilent-4287
Refer to standard electrical characteristic list
SRF
Agilent-4291 Agilent-E4991
Agilent-4291,
DC Resistance
Rated Current
Base on temp. rise & △L/L0A≦30%.
Saturation DC Current (Isat) will cause L0
to drop approximately △L(%).
Temperature Rise Test
ΔT 40℃Max
Heat Rated Current (Irms) will cause the coil temperature rise
approximately △T(℃) without core loss.
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
Mechanical Performance Test
Appearance:No damage.
Inductance:within±10% of initial value
Solder Heat Resistance
RDC:within ±15% of initial value and shall not exceed the specification value
Temperature
(°C)
Time
(s)
Temperature
ramp/immersion
and
emersion
rate
260 ±5
(solder temp)
10 ±1
25mm/s±6 mm/s
Number
of heat
cycles
1
Depth: completely cover the termination
Solderability Test
More than 95% of terminal electrode should be covered with solder.
Preheat: 150℃,60sec.。
Solder: Sn99.5%-Cu0. 5%。
Temperature: 245±5℃。
Flux for lead free: Rosin. 9.5%。
Dip time: 4±1sec。
Reliability Test
Preconditioning:Run through IR reflow for 2 times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles
Temperature:125±2℃(Bead)
Life Test
Temperature: 85±2℃(Inductor)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Thermal shock
Step1:-40±2℃ 30±5min
Step2:25±2℃ ≦0.5min
Step3:105±2℃ 30±5min
Number of cycles: 500
Measured at room fempraturc after placing for 24±2 hrs
Humidity:85±2﹪R.H,
Humidity Resistance Test
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
www.tai-tech.com.tw
hrs
P7
TAI-TECH
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Vibration Test
8. Soldering and Mounting
8-1. Soldering
Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for all wave and re-flow soldering systems.
If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools.
8-1.1 Solder re-flow:
Recommended temperature profiles for re-flow soldering in Figure 1.
8-1.2 Soldering Iron(Figure 2):
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that
a soldering iron must be employed the following precautions are recommended.
‧Preheat circuit and products to 150℃
‧355℃ tip temperature (max)
‧Never contact the ceramic with the iron tip
‧1.0mm tip diameter (max)
Iron Soldering
Reflow Soldering
PRE-HEATING
SOLDERING
20~40s
PRE-HEATING
NATURAL
COOLING
TEMPERATURE(C)
217
60~150s
200
150
SOLDERING
within 4~5s
TP(260 C / 40s max.)
TEMPERATURE(C)
‧Use a 20 watt soldering iron with tip diameter of 1.0mm
‧Limit soldering time to 4~5 sec.
60~180s
NATURAL
COOLING
350
150
Gradual cooling
Over 60s
480s max.
25
TIME(sec.)
TIME( sec.)
Reflow times: 3 times max.
Iron Soldering times: 1 times max.
Fig.1
Fig.2
8-2. Recommended PC Board Pattern
L
G(mm)
H(mm)
3.2
1.0
3.2
H
L(mm)
G
www.tai-tech.com.tw
P8
TAI-TECH
9. Packaging Information
9-1. Reel Dimension
C
B
D
A
Type
A(mm)
B(mm)
C(mm)
D(mm)
7”x8mm
8.4±1.0
50 min.
13±0.8
178±2
7"x8mm
9-2. Tape Dimension / 8mm
t
P
Ao
Bo
Po:4∮0.1
W:8.0∮
0.1
P2:2∮0.05
Series
Size
Bo(mm) Ao(mm) Ko(mm) P(mm)
HPC
3015
3.2±0.05
3.2±0.05
1.70±0.2
4.0±0.05 0.23±0.05
Ko
9-3. Packaging Quantity
Chip size
3015
Chip / Reel
2000
9-4. Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 15 to 80 grams
in the arrow direction under the following conditions.
165to180
Base tape
Room Temp.
Room Humidity
Room atm
Tearing Speed
(hPa)
mm/min
5~35
45~85
860~1060
300
Application Notice
‧Storage Conditions
To maintain the solderability of terminal electrodes:
1. TAI-TECH products meet IPC/JEDEC J-STD-020D standard-MSL, level 1.
2. Temperature and humidity conditions: Less than 40℃ and 60% RH.
3. Recommended products should be used within 12 months form the time of delivery.
4. The packaging material should be kept where no chlorine or sulfur exists in the air.
‧Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are minimized.
www.tai-tech.com.tw
t(mm)
P9
TAI-TECH
www.tai-tech.com.tw
很抱歉,暂时无法提供与“HPC3015TF-4R7M”相匹配的价格&库存,您可以联系我们找货
